• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Valued Contributor
    milton.fitzgerald
    Array & Offset NOT WORKING??? Acad2011
    667 Views, 6 Replies
    03-01-2012 02:05 PM
    To All,
    Has anyone run into the situation where the Array & Offset command are not working at all?
    I've tried this on all the "MEP" versions of  Acad2011 (I'm running "Global, Imperial, and Metric), and in all 3 cases the array and offset command are NOT WORKING. I even tried the "3D" array and again nothing worked.
    BTW, I went to my old machine (32 bit, Xp machine) and the array command was working fine. Of course, this was my original "OEM" version of AutoCAD2011.
    As usual, if anyone has any answer that would be great.
    Milt (a.k.a. Drafter1981)
    Milt Fitzgerald (a.k.a. Drafter1981)
    Siemens Industries (Full-Time Office Position)
    Fitz’ Digital Cad Service L.L.C. (Consulting Business)
    https://sites.google.com/site/fitzdigitalcadservice/
    Please use plain text.
    Re: Array & Offset NOT WORKING??? Acad2011
    03-01-2012 02:09 PM in reply to: milton.fitzgerald
    means what? AutoCAD crashes, command not found, you can't select objects, you get any error message in the command-line, ... ?
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    milton.fitzgerald
    03-01-2012 02:26 PM in reply to: milton.fitzgerald
    Clarification....nothing is working meaning the commands go the the prompts and then the review does not sow your items. Same with offset, meaning the command line  ask for you to select your item (line) that you want to offset you select it, give it the measurement, and then the command stops after you  pick the side, or hit enter.
    Even using offset with just a "Trough point" is not working.
    Hope this helps to clarify the problem
    Valued Contributor
    milton.fitzgerald
    03-01-2012 02:29 PM in reply to: milton.fitzgerald
    the review does not sow your items. "I meant the review does not show your items"
    03-01-2012 02:38 PM in reply to: milton.fitzgerald
    thank you clarifying it!
    Just to make sure: the _OFFSET command has an option for changing the layer from the resulting geometry to be placed onto the current layer .... you haven't switched OFF your current layer? Just try next time it happens to thaw and switch on all layer ... just to make sure.
    To MEP ... sorry, I don't use it, maybe if you ask in the forum for MEP (>>>here<<<) you may get more/better answers than mine.
    - alfred -
    Alfred NESWADBA
    Distinguished Mentor
    thepworth
    03-01-2012 04:02 PM in reply to: milton.fitzgerald
    are "pickfirst" and "pickadd" both set to 1?
    C3D 2011
    Intel Xeon E5630@2.53Ghz
    NVIDA Quadro NVS420 Dual Monitor
    12GB Ram / Win7 Professional 64bit SP1
    Valued Contributor
    milton.fitzgerald
    03-02-2012 08:36 AM in reply to: milton.fitzgerald
    Using the "Setvar" command to check my settings, I found "Pickadd" was set to # 2 & Pickfirst was set to # 1
    Should I change these?
    BTW... the Offset command is now working. I was hoping that mabey I just needed a "Hard Re-boot"
    (completely shutting down my computer) and the Array is still not working.
