• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Member
    Add/Remove object from working set when using edit block in place
    515 Views, 1 Replies
    09-02-2011 08:51 AM
    Hi
    I have just noticed that when I try to edit blocks in place, when I select objects to be added or removed from the working set using the button on the ribbon, instead of imediately adding or removing the selected objects like it alwas has done when I press enter, it now asks me to type either a to add or r to remove before carrying out the command.
    Its not the end of the world but just adds and extra bit of typing that I havent had to do before so it niggles.
    Anyone know what has gone screwy to cause this?
    David
    Please use plain text.
    Product Support
    Re: Add/Remove object from working set when using edit block in place
    09-20-2011 02:00 PM in reply to: david.whalley
    May be a good case to reduce the mouse clicks, etc.  I do believe that this would be very helpful to have in the program, and feel that you raise a very good case for enhancing the product.
    If you would take the time to go here:
    http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
    This is a feedback page where customers can make suggestions. This page is monitored by product managers who affect real change and this request can go a long way in changing the product for the better.
    Joshua Benoist, PE
    Senior Support Specialist
    Product Support
