AutoCAD 2010/2011/2012 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
AREA precision units
- Highlight
- Email to a Friend
- Report Inappropriate Content
Hi every body,
i have a werid number appear when a get the AREA of the attached rectangles shapes especially when i use SMD ucs.
for instance see the rectangle C07 74X39=2886.00000000 BUT i get the area like 2886.000000003.
why the precisions dosesn't all 0 !!!!!!!
kindly see the attachment
thanks
Re: AREA precision units
- Highlight
- Email to a Friend
imadhabash wrote:2886.00000000 BUT i get the area like 2886.000000003.
For all practical purposes those two numbers are equivalent.
Search for information on floating point math calculations.
What are your units?
What will be your measuring device?
What is your manufacturing/construction process?
Inventor Professional 2014 Edu 64-bit
- Highlight
- Email to a Friend
The accuracy is 0 before you rotate the rectangle, if you rotate in increments less than 90 it looses this accuracy giving an inaccuracy such as yours +/- of the value. But as noted the accuracy is pretty good for all practical purposes.
- Highlight
- Email to a Friend
dlipscombe wrote:But as noted the accuracy is pretty good for all practical purposes.
Pretty good? It is dead on for all practical purposes.
I think units (mm, M, light years...) need to be specified along with magnitude to have any real meaning.
- Highlight
- Email to a Friend
Autocad is a precision software, you dont expect to get two different values just because you rotated an object 30°, no matter how minute the discrepency it should give the same reading in all circumstances, after all rotating an object doesnt change the object? Yes your right it is dead on for all uses, nobody ever needs that sort of accuracy.
- Highlight
- Email to a Friend
dlipscombe wrote:Autocad is a precision software, you dont expect to get two different values just because you rotated an object 30°,
What is the precision of AutoCAD software. Be specific.
What is the programing routine for calculating the new position. Be specific. (you may simplify this one with hand-calc trig rather than specific programing algorithm)
- Highlight
- Email to a Friend
As we can see from the OP they offer 8 decimal places but can only deliver 7, should not offer something you cannot achieve.
- Highlight
- Email to a Friend
Precision is not about decimal places but significant figures. There are 13 significant figures, not 8 decimal places. The original drawing did not have perfectly drawn rectangles. The dimensions were off in the 12th significant figure (which is superb unless you want perfection).
There is no need to dimension or worry about these kinds of extreme precisions that cannot be measured or produced by machine. A typical surveyor might measure with an error of 1 part in 5000. So a 74m property might actually be 74.01m or it might be 73.99m. The area listed is well within the measurable precision.
