• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Distinguished Contributor
    Accepted Solution
    APPLOAD fails - not loaded
    565 Views, 7 Replies
    10-12-2012 09:43 AM
    AutoCAD 2011 - the appload.arx is not being loaded when acad2011 is started.  The appload.arx and apploadres.dll are in the correct foldet (AutoCAD 2011).  Just to make sure, I added AutoCAD 2011 to the search path, still does not load.  Since appload does not load, none of the files in the startup suite are loaded.  I am sure that the appload was loaded 2 weeks ago - this is a user's compuiter and not mine (I have been comparing files and folders to mine as a base, since it works on mine).  Search path and folders are identical to mine.
    I think I have run into this before but cannot remember how it was fixed or if I did indeed have this issue.
    Please use plain text.
    *Expert Elite*
    Re: APPLOAD fails - not loaded
    10-13-2012 09:27 AM in reply to: jeff.whitney
    What happens if you try to load these file manually? If you get any messages ==> show them here!
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    *Expert Elite*
    pendean
    10-14-2012 05:30 AM in reply to: jeff.whitney
    What do you mean exactly? APPLOAD the command does not work?
    What exactly are you trying to get installed and running?
    Otherwise you probably should be looking to use an ACADDOC. LSP file to autoload add-ons instead.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    10-15-2012 07:49 AM in reply to: alfred.neswadba
    I can load normaly (load "function"),  but the appload dialogue will not display - I get the error message ""appload failed"
    10-15-2012 07:54 AM in reply to: pendean
    when I try to use appload, I get the error message "Initializing - load failed -'appload' "
    Even if I use acaddoc.lsp Dean there are still several functions that are not needed all the time that would be easier for the user to load with appload rather than using the (load "...")  - and if that ain't a lot of loads I don't know what is! :manlol:
    *Expert Elite*
    pendean
    10-16-2012 05:56 AM in reply to: jeff.whitney
    What changed recently? New AutoCAD profile? New screen menus?
    Did you try a Windows Restore back to a week or month it all worked?
    Have you tried a repair reinstall of AutoCAD?
    software doesn't break on it's own, something is always a trigger and usually just repathing everything does nothing to fix a problem with a broken file.
    10-16-2012 07:41 AM in reply to: pendean
    Nothing chnaged that I kow of - other than probably installation of other non-cad software.
    Will try the repair/reinstall route (wanted to avoid re-installation)
    If it works will mark it solved
    10-16-2012 08:01 AM in reply to: jeff.whitney
    repair did it, relatively painlessly
