• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Distinguished Contributor
    JIMDONALDSON6595
    ADOBE 'Flattening' Acad PDF files
    2009 Views, 6 Replies
    07-12-2011 01:10 PM
    I'm using the DWG to PDF pc3 file to create PDF's for distribution. Dwg's are all 2D and saved as 2007. But when clients and I print the PDF's (mostly Acrobat Reader) it says it is flattening the files and then prints the sheet(s).
    Unfortunately this take a long time to print, depending on the number of sheets in the PDF file.
    Is there a setting I'm missing, or some other fix for this?
    Jim
    Please use plain text.
    pendean
    Re: ADOBE 'Flattening' Acad PDF files
    07-12-2011 08:00 PM in reply to: JIMDONALDSON6595
    If you want to avoid that, turn off the two features that trgger it: having layers in the PDF (flattening of...), and disable plot overwrite (creates layering effect, rely on draworder instead).
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    JIMDONALDSON6595
    07-13-2011 05:41 AM in reply to: pendean
    I found the 'Include Layer Information' option in the DWG To PDF.pc3 file. (See Attached)
    But where do I find the Plot Overwrite?
    Jim
    pendean
    07-13-2011 10:37 AM in reply to: JIMDONALDSON6595
    Merge Control entry right above it.
    JIMDONALDSON6595
    07-13-2011 03:04 PM in reply to: pendean
    That worked Dean, thanks. Editing the PC3 file only effects direct plotting though. Had to find similar settings in the publish command.
    Jim
    hardin
    07-29-2011 10:21 AM in reply to: JIMDONALDSON6595
    Sometimes, when printing from Acrobat Reader, pick the Advanced button in the print dialog box and check "Print as Image". That will make your computer do all the processing before sending the print 'image' to the printer. Otherwise, the printer has to do all the processing.
    At least that's the way I understand it.
    Sometimes it helps, sometimes not.
    Learn, Practice, Get Better
    http://autocad-lkh.blogspot.com
    07-29-2011 10:46 AM in reply to: hardin
    That may compromise the quality of the print because it translates all the vector information in the PDF to raster before sending to the printer.  Depends on the type of PDF and the result you expect, I can see some use of that method, though.
