• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Valued Contributor
    A bug?
    195 Views, 3 Replies
    05-13-2010 02:50 PM
    When inserting a block with attributes, if, in the insert dialogue box the Specify On-Screen box is checked under insertion point, the values for the attributes are entered on the command line. If the Specify On-Screen box is not checked, the attribute values are entered in the Edit Attribute dialogue box.
    Is it a bug or one of those obscure settings?
    Please use plain text.
    Valued Mentor
    Re: A bug?
    05-13-2010 02:57 PM in reply to: DavidJFuller
    The ATTREQ variable controls whether the values get filled in on the command line or the dialog box.
    0 > dialog box
    1 > command line
    Edited by: tschau3@hotmail.com on May 13, 2010 2:58 PM Edited by: tschau3@hotmail.com on May 13, 2010 3:01 PM
    Valued Contributor
    Re: A bug?
    05-13-2010 03:16 PM in reply to: DavidJFuller
    This variable controls whether or not the values for the attributes are entered at insert time, not how they are entered at inset time. Edited by: DavidJFuller on May 13, 2010 10:17 PM
    Valued Mentor
    Re: A bug?
    05-13-2010 03:28 PM in reply to: DavidJFuller
    I see what you're saying...I get the same behavior here. It happens in 2010 as well.
