• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Valued Contributor
    [ 3DModeling ] GRIP Problem!
    489 Views, 5 Replies
    07-28-2010 11:21 AM
    I've been 3d modeling since AutoCAD 2005, and recently I noticed something very inconvenient.
    If an object (Object A) is behind another object (OBJECT B), then the 3D Solid grips that should appear on OBJECT A get hidden, forcing me to change my view shade (VSCURRENT) to wire frame in order to access those hidden grips.
    Is there a system variable which would allow me to view those grips like I would in the wireframe?
    I attached two images.
    I want to see ALL those grips which are visible in the wireframe mode the same in the shaded(Realistic/Conceptual etc.) mode.
    Thanks in advance.
    Please use plain text.
    Active Contributor
    randomnewb
    Re: [ 3DModeling ] GRIP Problem!
    07-28-2010 12:00 PM in reply to: oyy5408
    just out of curiosity, is this something that you were able to do before 2011? try reading here >http://docs.autodesk.com/ACD/2011/ENU/filesACR/WS1a9193826455f5ffff8c2a10d68757bb5-7e69.htm <
    let us know if that helps :smileyhappy:
    Valued Contributor
    07-28-2010 01:58 PM in reply to: oyy5408
    Yup I think this feature disappeared since 2009. NOT 100% sure though.
    System variable 3DSELECTIONMODE did not solve the issue.
    I would TRULY love to have this feature back.
    Active Contributor
    randomnewb
    07-28-2010 02:28 PM in reply to: oyy5408
    Valued Contributor
    07-28-2010 04:57 PM in reply to: randomnewb
    THANK YOU!
    CAN I WORSIP YOU?? OH MAN THANKS!
    Valued Contributor
    Gabriel.N
    05-08-2012 10:02 AM in reply to: oyy5408
    Wow, thanks a lot too!:smileyvery-happy:
