• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Member
    renie.ak
    3D File created on a windows AutoCAD not editable in MAC AutoCAD
    216 Views, 8 Replies
    10-20-2011 10:42 AM
    I've got a problem editing the 3D drawing that i just drew on my windows AutoCAD 2008 on a AutoCAD 2011 for mac.
    I'm not even able to select an object. What could be the problem?
    Thanks in advance.
    Please use plain text.
    Re: 3D File created on a windows AutoCAD not editable in MAC AutoCAD
    10-20-2011 10:50 AM in reply to: renie.ak
    what does _AUDIT report?
    - alfred -
    Alfred NESWADBA
    Active Member
    renie.ak
    10-20-2011 11:18 AM in reply to: alfred.neswadba
    Hi alfred,
    I'm new to AutoCAD and am not familiar with "audit". but after searching the net for it, i tried "auditctl" and when it prompted i entered0 "1". But did not receive a ".act" file as said. also tried just "audit" but it asks for "s or no" confirmation to fix any errors if found.
    So wat whould i do?
    Renie Ak
    10-20-2011 11:23 AM in reply to: renie.ak
    the way I have asked for is to type in the command _AUDIT (I also have placed a hyperlink to the help-file behind the name! I did it here once more).
    And then answer yes, let the program now do the work and you will get the info of what happened, what has to be repaired (what was repaired) all in the command are. That could be copied to a textfile (for uploading here) or direct into your answer.
    - alfred -
    Alfred NESWADBA
    Active Member
    renie.ak
    10-20-2011 11:41 AM in reply to: alfred.neswadba
    Alfred,
    Here it is ... I was not able to copy it... So took a sreenshot...
    10-20-2011 12:00 PM in reply to: renie.ak
    ok, "Total errors found 0" is a good message, so we can concentrate on two things
    - either there are some elements that the Mac-AutoCAD does not know (e.g. object from ACA, Civil3D, ...)
    - or what happens to the application
    So can you try some things:
    - try to get the objects selected with _QSELECT
    - what happens if you first start a command, e.g. _MOVE and then select the object
    The more info you can give, the more info we can return (at least try to).
    - alfred -
    Alfred NESWADBA
    Active Member
    renie.ak
    10-21-2011 12:56 AM in reply to: alfred.neswadba
    Hi Alfred,
    So here is a video answering the questions that you've asked. I guess showing it to you would help more.
    I've narrated the problem there. So turn on the volume... :-)
    http://www.youtube.com/watch?v=VxFUNblDYzI
    Renie Ak
    10-21-2011 03:17 AM in reply to: renie.ak
    first: this is at least 1 kudo worth .... for how you prepared the description for your problem .. great! :smileyvery-happy:
    And then I'm real sorry that I can't give any more support. As you saw in the other drawing with the solid-object it may be a problem of the mac-version, either a bug or "as-designed" ... I really don't know that. Sorry!
    maybe there will come another one who has the mac-version and can help you, or (I think the better option) you go to >>>this forum (AutoCAD for Mac)<<< and give your question a new try (refrence to this thread so it's not identified as crossposting).
    Good luck anyway, - alfred -
    Alfred NESWADBA
    Active Member
    renie.ak
    10-21-2011 11:26 AM in reply to: renie.ak
    Hi Alfred,
    Thanks for the kudos :smileyhappy:... I just thought it would be better if i'd show you the problem than just explaining to you through words.
    But anyways thanks for your help... And yes i'll post this on the mac forum!!!
    Thank You
    Renie Ak
