• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Valued Contributor
    Re: 2012 PDF's crash system
    08-26-2011 09:18 AM in reply to: PETEWERRIN3578
    The fact that PDFs regenerate so slowly makes them inefficient in our environment. If they are bitonal, we convert the PDFs to TIFS and attach the TIF files. If they are multitonal, we convert to JPG and attach. This substantially speeds up regeneration time without a substantial decrease in quality. However, you do get rid of the PDF enhanced functions such as being able to do snap points, but our images are generally reference only type information. Anyways, food for thought.
    Please use plain text.
    Valued Mentor
    TrevN
    08-29-2011 11:58 PM in reply to: rmckee
    Well using 32bit with 2012 could well be the problem.
    AC is now so power hungry it's mad, and I wouldn't even consider using it on anything less than 64bit.
    2011 was bad enough for crashes due to lack of memory, I can't imagine what 2012 is like. I's switch to 64bit and I'd be surprised if the same problem occured, but that's easier said than done!
    Member
    kim.jackson
    08-30-2011 06:22 AM in reply to: TrevN
    Actually, one of our IT guys was able to produce the same problem and he has a 64-bit machine.  We are thinking it is a bug but who knows.
    Thanks for replying.
    Valued Mentor
    TrevN
    08-30-2011 06:35 AM in reply to: kim.jackson
    2012 on 64 bit isn't perfect, and if it's been running for several hours it still uses alot of memory and only clears if you start a new session.
    2012 on 32 bit, no thanks!
    Member
    kim.jackson
    08-30-2011 06:38 AM in reply to: TrevN
    I agree!  However, try to explain to non-engineer, non-CADD upper management that we need higher end machines that are capable of running more than Microsoft Office!  I'm sure you've never experienced that <<sarcasm>>.  :smileywink:
    Valued Mentor
    TrevN
    08-30-2011 06:41 AM in reply to: kim.jackson
    Never, nor the need to dual monitors, or to have admin rights to machines, or..... where would you like to to end?!!!!!!
    Product Support
    08-30-2011 07:39 AM in reply to: PETEWERRIN3578
    Are you creating the PDF files with DWG To PDF.pc3?
    We could try to reproduce the issue if you send the files.
    Please use eTransmit to pack all the needed files, then explain in detail the settings to create the PDF.
    Cheers,
    Luciane
    Luciane Conceicao
    Product Support Specialist
