• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2009
    can't copy multiple objects
    177 Views, 2 Replies
    01-19-2012 01:00 PM
    This is probably a stupid question.  For some reason the copy command suddenly started only allowing to select one object.  If I click copy and select a line, then select a second line, it selects the second line and de-selects the first line.  It does allow me to copy multiple objects using a crossing window.  But I cannot individually click multiple objects as it will deselect the previous object with each new click.  I'm sure this must be a simple setting that got unchecked somewhere.
    thanks
    Re: can't copy multiple objects
    01-19-2012 01:06 PM in reply to: russwood
    Is your PICKADD system variable set to 1?
    01-19-2012 01:11 PM in reply to: Johneng
    thanks I knew it was simple :smileywink:
