• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2009
    Active Contributor
    Saving Block Referrence Edits
    66 Views, 4 Replies
    02-03-2012 12:26 PM
    Getting this error when attempting to save reference edit.  Unable to save edits.
    Command: _amrefclose Errors found in references to other objects:
    ** Object reference missing: AcDbLine, to AcDbDimAssoc.
    ****Sage
    Re: Saving Block Referrence Edits
    02-04-2012 06:37 PM in reply to: rebeccabennett8908
    Try to fix the file by running AUDIT or RECOVER, then Purging and Qsave, before you refedit to see if the problem goes away.
    Please mark any response as "Accept as Solution" if it answers your question.
    Dean Saadallah
    http://LTisACAD.blogspot.com
    RSS: http://ltisacad.blogspot.com/feeds/posts/default
    Twitter: http://twitter.com/LTisACAD
    Pinterest: http://pinterest.com/pendeaninc/pins/
    Active Contributor
    Re: Saving Block Reference Edits
    02-06-2012 06:35 AM in reply to: rebeccabennett8908
    Thank you for the reply.  I restarted my machine and that seemed to work.  But if it happens again I will try your solution and let you know.
    Active Contributor
    02-07-2012 11:25 AM in reply to: rebeccabennett8908
    That worked for fixing the block once, but subsequent attempts to edit the block come up with the same error.
    However when I run the Audit and Purge I come up with this message:
    "Do you want to purge layer $AUDIT-BAD-LAYER?"
    So it must be linked to a layer somehow.
    ****Sage
    02-07-2012 02:42 PM in reply to: rebeccabennett8908
    Good assumption: as a test, use WBLOCK and create a new file out of all the content you have in MODELSPACE, then use that file for a while. See if the problem goes away.
    Dean Saadallah
