AutoCAD 2009
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Printing is blurred lineweight s too big
- Highlight
- Email to a Friend
Amateur AutoCad needs some help
I have a DWG file that i'm trying to print A3. When i print preview it goes from looking great in the 'layout' screen but the preview is as if all the lines/drwaing text have been expanded
I can print out other DWG files no problem. Just have (3) files from the same client that do the same thing
We have these files and have just edited some things on them such as removing objects / lines etc so modifed to our needs. nothing really big
Can anyone help and point me in the right direction please. I would be most appreciated
I have made a summary of what i have tried
- tried a different printer
- tried different size papers A1-A4
- fit to paper
- scale lineweights in print options (even bigger)
- scaling in printer settings
The only way i get the drawing to look properly on the printer is to zoom in. Obviously then that would mean me getting a 1/10th of the drawing onto a sheet of A4. I could suppose do that and sellotape them all together.... LOL
I have attached a shot of the layout and a shot of the print preview
Any help greatly appreciated
Re: Printing is blurred lineweight s too big
- Highlight
- Email to a Friend
go to the layout and start the plot-dialog, now check the setting "scsle lineweight". If it's on ==> turn it off and try to plot once more. (>>>details<<<)
Good luck, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
- Highlight
- Email to a Friend
This is not ticked and i have tried it both with it ticked and unticked and the plot is even thicker/fatter
- Highlight
- Email to a Friend
How are lineweights achieved? Note the command line repeats LINEWEIGHT, that's the issue most likely, they are set to thick.
Plotting to what in the screenshots? Using what driver? use a PC3 file too?
Dean Saadallah
http://LTisACAD.blogspot.com
RSS: http://ltisacad.blogspot.com/feeds/posts/default
Twitter: http://twitter.com/LTisACAD
Pinterest: http://pinterest.com/pendeaninc/pins/
- Highlight
- Email to a Friend
Not sure how lineweights were achieved. This is a Drawing supplied by a thrird party. Our only involmement with it was to remove(erase) some information and then re-print it for our own records
Plotting - I'm only printing A3 so to a A3 printer. Doesn't matter what i choose even pdf.pc3 it is all the same
- Highlight
- Email to a Friend
Go into modelspace.
Select everything.
Start PROPERTIES command
LINEWEIGHT category towards the top, change it to 0.00
QSAVE your drawing.
If you still get linewights, then youo need to edit the plot style tables to fix it: that's on your PLOT pop-up, help yourself.
Dean Saadallah
