AutoCAD 2009
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Layer State Manager
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I’m an avid user of the capacities of the ‘’Layer State Manager’’
Somehow, lately something goes wrong with this feature !
While I’m still able to restore old saved layer states, the manager won’t accept anymore editing the properties of the layers in those saved states, as changing the color of a layer or turning off / on layers.
Now, the only way I can do this is like that:
- From the ‘’Layer State Manager’’ I restore the saved state I intend to edit.
- I close the ‘’Layer State Manager’’ and open the ‘’Layer Properties Manager’’
- I make in the ‘’Layer Properties Manager’’ all the changes I want for my saved layer state
- I close the ‘’Layer Properties Manager’’ and open back the ‘’Layer State Manager’’
- I choose in the ‘’Layer State Manager’’ between my saved layer states the one I wanted to edit and click on ‘’Save’’ button
So, this procedure is long and not logical. The question is - How can I restore the EDIT capacities of the ‘’Layer State Manager’’ ???
Thanks in advance
I attached two screen captures showing (I hope) the problem...
Re: Layer State Manager
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Check out this:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
www.geaux-cad.blogspot.com
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for trying!
Unfortunately it didn’t work… and I tried both procedures found in your link !
I forgot to mention that I’m using the same drawing files like before, files in which the command “Layer State Manager” worked fine. So the files are the same and the machine is the same.
So, as usually happens, the change in the behavior of the “Layer State Manager” AutoCAD feature come suddenly and out of the blue sky.
I’m suspecting (but I’m not a specialist) that maybe (maybe…) some changes in the company server (where the code resources and stuff like this of the AutoCAD programs are stored) were done in the Holiday season (vacation in my company) and therefore those are affecting the behavior of AutoCAD in my machine…
But this is just a guess…
Maybe I should try to re-install AutoCAD, who knows…?
Layer State Manager - update
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi everyone
I just want to add a new hint.
My machine is a laptop with Autocad 2009 installed.
While I'm using Autocad in the office of my company I'm plugged in a dock station, which is connected to the company servers and also to a secondary monitor.
In this situation I'm not able to use the features of "Layer State Manager" as I mentioned in my first post.
On the other hand, when I'm using Autocad on my laptop without beeing plugged in the dock station (and without the secondary monitor also), all the features of the "Layer State Manager" are working properly and I'm able to use, edit and save layer states.
So, what could be changing in my Autocad settings when I'm plugged in my company dock station...???
Thanks again if you can help !
