AutoCAD 2007/2008/2009
molson1
Message 1 of 8 (1,894 Views)
xref - hide
1894 Views, 7 Replies
04-09-2009 09:07 AM
Is there anyway to hide part of an xref? The drawings I am trying to work with have all the plans on one sheet so I don't want to xclip - I want to hide information in the middle of the drawing.
*Tim Decker
Message 2 of 8 (1,894 Views)
Re: xref - hide
04-09-2009 01:15 PM in reply to: molson1
WIPEOUT command should do it.
Valued Contributor
tom_kelly
Message 3 of 8 (1,894 Views)
Re: xref - hide
04-11-2009 03:09 AM in reply to: molson1
As suggested earlier you can use Wipeout Or If the part you want to hide is on different layer, then freeze that layers in X-ref drawing. Third option would be to use mulitple/polygonal viewports.
Please check and let me know if this helps
Tom
www.indovance.com
Active Contributor
dazza10101
Message 4 of 8 (1,894 Views)
Re: xref - hide
04-22-2009 03:18 AM in reply to: molson1
Xclip?
molson1
Message 5 of 8 (1,894 Views)
Re: xref - hide
04-22-2009 07:20 AM in reply to: molson1
I just want to hide part of the middle of the drawing.
Wipeout hides everything - on my drawing and on the reference file.
I could make a really weird polygon for xclip, I guess.
Microstation can clip and keep either the inside of the fence or outside of the fence. That is what I am looking for.
*Tim Decker
Message 6 of 8 (1,894 Views)
Re: xref - hide
04-22-2009 07:47 AM in reply to: molson1
You can use the Draw Order to position the Wipeout above the
entities you want to wipeout, and below everything
else.
molson1
Message 7 of 8 (1,894 Views)
Re: xref - hide
04-22-2009 09:21 AM in reply to: molson1
Yahoo!!!
Thanks!
molson1
Message 8 of 8 (1,894 Views)
Re: xref - hide
04-29-2009 10:40 AM in reply to: molson1
This is wonderful - on my computer screen in paper and in model space. However, when I plot the image that I have wiped out is still there.
I have tried changing the wipeout frame from a plot layer to a no-plot layer and back again.
Any suggestions?
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
