AutoCAD 2007/2008/2009
shameem4u
Message 1 of 2 (502 Views)
xref File name change
502 Views, 1 Replies
01-07-2012 11:56 PM
Hallo,
Here I have a problem
I have a xref to a drawing need to add a new version for the xref with different file name, while I change the path the file name on the xref manage keep the old one, Is there any way to change the name over there same as the new one....
If i reattach I have to do alot to fit with viewports
Regards
Shameem
*Expert Elite*
Alfred.NESWADBA
Message 2 of 2 (494 Views)
Re: xref File name change
01-08-2012 02:05 AM in reply to: shameem4u
if you open your drawing you get now a "missing XRef" message? If so you should have the possibility to show then the new file, hence I don't know if that worked back to 2009,
If none of these XRef-dialog options fit there is a chance to save your drawing as DXF, then open the DXF with an ascii-editor like Notepad+ (at least an editor that can load big files). There you can search for the old path+name and replace against the new one. After saving this load it in AutoCAD and do a _SAVEAS to save it as DWG file.
Goos luck, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
