AutoCAD 2007/2008/2009
New Member
jhfbscc
Message 1 of 4 (281 Views)
properties and quick select stop recognizing dwg entities
281 Views, 3 Replies
03-20-2012 11:32 AM
What would cause the Properties command and the Quick Select command to stop recognizing drawing entities?
If I select some objects and hit properties it tells me no selection. Same in Qselect.
Ther is a variable that will shut off dialog boxes but I don't remembeer it.
New Member
jmackey
Message 2 of 4 (265 Views)
Re: properties and quick select stop recognizing dwg entities
03-20-2012 02:57 PM in reply to: jhfbscc
"FILEDIA" should be set to 1 for dialogs, hope that helps
New Member
jhfbscc
Message 3 of 4 (243 Views)
03-21-2012 05:49 AM in reply to: jhfbscc
FILEDIA only controls the dialog box for finding & opening files.
There is another variable that turns off dialog boxes for other commands, INSERT for example.
New Member
ianangry
Message 4 of 4 (153 Views)
05-01-2012 08:42 PM in reply to: jhfbscc
I had exactly the same problem.
Go to Control Panel
Select Uninstall a Program
Select AutoCad 2008
It will offer a button to Uninstall/Change.  Click it.
Select Repair or Reinstall
Select Repair my AutoCad 2008 installation and click next.
That's it.  You don't even need the install disk.
Brilliant
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
