AutoCAD 2007/2008/2009
Member
Message 1 of 7 (178 Views)
Accepted Solution
problem with suddenly saved files!
178 Views, 6 Replies
07-16-2012 06:12 AM
i made a mistake and i saved a wrong drowing file on a very important file! i used recovery manager but it just shows the last one, what should i do to reach the file befor??
i am using autocad2007 and the file is DWG.
it should be something like undo or something:smileysad:
thanks enyway
*Expert Elite*
Alfred.NESWADBA
Message 2 of 7 (173 Views)
Re: problem with suddenly saved files!
07-16-2012 07:32 AM in reply to: ardavan_v8
you have two chances:
  • you have a BAK-file from the one you overwrote, then you can rename it to *.DWG and open it.
  • you have a backup from your filesystem, then start a restore
Good luck, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Member
Message 3 of 7 (169 Views)
07-16-2012 08:30 AM in reply to: Alfred.NESWADBA
hi alfred
by changing to *.DWG nothing changes... it looks just its changing name, not the format...
and for secund chance, where do this filesystems save??
*Expert Elite*
Alfred.NESWADBA
Message 4 of 7 (166 Views)
07-16-2012 09:25 AM in reply to: ardavan_v8
I meant the normal Backup-system that runs daily (or however it's configured on your network/your system) to save your data to any other device for archiving and for backup.
- alfred -
Alfred NESWADBA
Member
Message 5 of 7 (165 Views)
07-16-2012 09:35 AM in reply to: Alfred.NESWADBA
hi again alfred,
i undrestud,
do you know how i can chand the Suffix? how should i change .BAK to .DWG ? my system dosnt change this by just renaming...
*Expert Elite*
Alfred.NESWADBA
Message 6 of 7 (163 Views)
07-16-2012 09:47 AM in reply to: ardavan_v8
In Windows-Explorer right-click onto the file and start "rename".
If you see no extensions at all then go to the options of Windows-Explorer and activate the option for showing known file-extensions (>>>details<<<).
- alfred -
Alfred NESWADBA
Member
Message 7 of 7 (158 Views)
07-16-2012 10:03 AM in reply to: Alfred.NESWADBA
yeeee, it worked by changing .BAK to .DWG! thanx you just saved me:smileyvery-happy:
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
