AutoCAD 2007/2008/2009
Valued Mentor
mrkaplan
Message 1 of 8 (420 Views)
express tools wont load
420 Views, 7 Replies
01-10-2013 02:28 AM
today for no apparent reason express tools will not load  . autocad behaves as if they are not installed .
they has always worked ok before that
does anyone have an idea why this happened
and is there a fix without  reinstall from cd ?   thank you
Alfred.NESWADBA
Message 2 of 8 (417 Views)
Re: express tools wont load
01-10-2013 03:33 AM in reply to: mrkaplan
verify the supportpaths (that one of the paths points to the ExpressTools folder) and verify if the menu ACETMAIN is loaded.
BTW:
what info do you see (that we don't see) that makes you thinking that?
- alfred -
Alfred NESWADBA
Valued Mentor
mrkaplan
Message 3 of 8 (415 Views)
01-10-2013 04:26 AM in reply to: Alfred.NESWADBA
any express command says " no function definition"
support path are ok
Patchy
Message 4 of 8 (409 Views)
01-10-2013 04:37 AM in reply to: mrkaplan
Check the DEMANDLOAD variable (Set it to 3)
Alfred.NESWADBA
Message 5 of 8 (408 Views)
>> support path are ok
And looking with the Windows-explorer into the folder to which the support-path points ==> does this folder exist and are there file in it?
- alfred -
Alfred NESWADBA
Valued Mentor
mrkaplan
Message 6 of 8 (393 Views)
01-12-2013 02:40 AM in reply to: Alfred.NESWADBA
thanks to you both . i haven tried DEMANDLOAD as i read the message too late . I might try next week .
i dont believe the  issue is related to content of support folder . (besides, it is normal) .  to my knowledge acetmain.cui has graphic interface , not core commands.
what i did finally was switch to another session  : then  expresstools loaded .
but some of acad behaviour was strange .  Adcenter and toolpalettes windows were sort of difficult to move even though LOCKUI is set to 0 .
I am starting to think this is an issue with this pc.  on any session system gives error messages,  and i am unable to load profiles because of registry error .
Alfred.NESWADBA
Message 7 of 8 (385 Views)
01-12-2013 03:20 AM in reply to: mrkaplan
In that case try to repair (or if needed uninstall and reinstall) AutoCAD.
- alfred -
Alfred NESWADBA
Valued Mentor
mrkaplan
Message 8 of 8 (368 Views)
01-13-2013 10:47 PM in reply to: Patchy
DEMANDLOAD was set to 3 .
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
