AutoCAD 2007/2008/2009
New Member
Message 1 of 4 (166 Views)
dimscale replacement
166 Views, 3 Replies
06-19-2009 07:25 AM
I have a lsp routine
that breaks a line in both directions the distance is per
the dimscale
now the dim scale is basicly off with annotative scaling on
is there another comand that can be used in its place
i tried cannoscalevalue but the #'s it gives back gets bigger the smaller the scale is
(the oposite of how dimscale worked)
lsp below
(defun C:BL (/ omode a b c pt1)
(defun *error* ()
(setvar "orthomode" omode)
(setvar "osmode" osmod)
(princ "\nError detected...aborting")
(terpri)
(setq SCL (getvar "dimscale"))
(setq omode (getvar "orthomode"))
(setq osmod (getvar "osmode"))
(setvar "orthomode" 1)
(setvar "osmode" 32)
(setq a (getpoint "\nSelect INTERSECTION :"))
(setvar "osmode" 512)
(INITGET "X")
(setq pt1 (getpoint a (strcat "\nSCL=" (RTOS SCL 2 2) "-Please pick lower line Yizil: Nea ")))
(if (= PT1 "X")
(progn
(*error*)
(exit)
(setvar "osmode" 0)
(setq b (angle a pt1))
(setq c (* SCL 0.040))
(COMMAND "BREAK" PT1 "F" (POLAR A B (- C)) (POLAR A B C))
any ideas
any help would be great
GrantsPirate
Message 2 of 4 (166 Views)
Re: dimscale replacement
06-19-2009 01:02 PM in reply to: jedijermx
Divide the cannoscalevalue into 1
1 / 0.0208333333 = 48
New Member
Message 3 of 4 (166 Views)
06-22-2009 06:49 AM in reply to: jedijermx
do you know how to write that in the above script?
GrantsPirate
Message 4 of 4 (166 Views)
06-22-2009 01:19 PM in reply to: jedijermx
(setq SCL (/ 1.0 (getvar "cannoscalevalue")))
I make no claims to being an accomplished lisp writer, but the above should work.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
