AutoCAD 2007/2008/2009
Active Contributor
bertbert
Message 1 of 9 (526 Views)
dimensions wrong in layout
526 Views, 8 Replies
09-30-2011 05:40 AM
hello there,
i am stumbling on a very strange problem that has never occurred until now.
i want to set dimensions on a layout and all vertical dimensions seem to be wrong whereas the horizontal ones are ok. if i set dimensions in the paper-space they are ok either way. any idea what this could be?
regards,
bert
Alfred.NESWADBA
Message 2 of 9 (525 Views)
Betreff: dimensions wrong in layout
09-30-2011 05:45 AM in reply to: bertbert
>> seem to be wrong
What is "wrong"? Color, lineweight, linetype, dimension-value, ...?
If you can upload a drawing it would be great (and I think much faster to get a result).
You tried _AUDIT to repair any problems within the DWG-database?
You checked your dimension-style? You tried the same within another drawing?
- alfred -
Alfred NESWADBA
Active Contributor
bertbert
Message 3 of 9 (523 Views)
09-30-2011 05:57 AM in reply to: Alfred.NESWADBA
hi,
it is the value of the dimention that is wrong. exp: a value that should be 175 appears as 173
bert
Alfred.NESWADBA
Message 4 of 9 (520 Views)
09-30-2011 06:06 AM in reply to: bertbert
without seeing the drawing I would check:
a) if I have used the object-snap points correctly
b) if there has been any modification to the scale of the viewport
- alfred -
Alfred NESWADBA
Active Contributor
bertbert
Message 5 of 9 (519 Views)
09-30-2011 06:32 AM in reply to: Alfred.NESWADBA
thanks for having a look!!!
bert
Patchy
Message 6 of 9 (511 Views)
09-30-2011 07:24 AM in reply to: bertbert
Because in this viewport you have a slight Z in the UCS.
Try dimensioning it again in the new drawing.
Active Contributor
bertbert
Message 7 of 9 (508 Views)
09-30-2011 07:34 AM in reply to: Patchy
ok! thank you very much!!!
how can i get rid of it? it doesn't show in the properties.
bert
Patchy
Message 8 of 9 (505 Views)
09-30-2011 07:43 AM in reply to: bertbert
Go into each viewport, and type in UCS, W  and then PLAN, Current to correct each viewport UCS.
or copy the correct viewport and redo Zoom XP.
Active Contributor
bertbert
Message 9 of 9 (501 Views)
09-30-2011 07:51 AM in reply to: Patchy
thank you very much for your help!!!
have a nice evening!
best regards
bert
You are not logged in.
    Come hangout with Autodesk Support Specialist and AutoCAD guru Volker Cocco, to learn about Precision Drafting: Object Snaps and Object Tracking on July 31 @ 11:00 AM PST.
    Click here for registration information!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
