AutoCAD 2007/2008/2009
Active Member
wellsws
Message 1 of 7 (282 Views)
dim style keeps overriding
282 Views, 6 Replies
06-13-2012 08:50 AM
We still use multiple dim styles for dimensioning (slowly moving over to annotative text).  I'm running into an issue where I save a template file with the multiple dim styles we use.  When I open the template, for some reason the first dim style, in this case "DIM 1", automatically has an overriden version when I open the dimension style manager.  Any ideas why this is happening?  I've attached an image showing what's happening.
Patchy
Message 2 of 7 (279 Views)
Re: dim style keeps overriding
06-13-2012 08:55 AM in reply to: wellsws
Do you have any autolisp loaded when your drawing started?
Active Member
wellsws
Message 3 of 7 (276 Views)
06-13-2012 09:01 AM in reply to: Patchy
I'm not sure.  How do I check to see if there are?  I'm pretty much a novice at this point.
Patchy
Message 4 of 7 (273 Views)
06-13-2012 09:06 AM in reply to: wellsws
Start a drawing, hit F2, read and see what is loaded.
Active Member
wellsws
Message 5 of 7 (271 Views)
06-13-2012 09:12 AM in reply to: Patchy
Got it.  We are using a fastener lisp routine for steel shapes.  However, the overriding dim style is only happening in certain files.  The lisp routine is loaded with every file.  See attached image.
Patchy
Message 6 of 7 (245 Views)
06-13-2012 09:46 AM in reply to: wellsws
Loaded is one thing, until you actually use a command in that lisp, that's when it change your dimstyle and not restoring it.
Why not try to stop Al steel program at start up  and see if your dimstyle will change.
scot-65
Message 7 of 7 (236 Views)
06-13-2012 03:38 PM in reply to: wellsws
If you cannot find the source of this problem, use a band-aid.
In your S::smileyfrustrated:TARTUP, enter this at the very end:
(setvar 'CMDECHO 0)
(command ".dim" "Restore" (getvar 'DIMSTYLE) "Exit")
(setvar 'CMDECHO 1)
(princ)
Scot-65
Dyslexia is a permanent physical disability that cannot be seen.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
