AutoCAD 2007/2008/2009
jbcanam
Message 1 of 7 (3,192 Views)
convert spline to polyline
3192 Views, 6 Replies
01-06-2008 10:07 AM
how do I convert a spline to a polyline. I tried the flatten command but autocad 2007 does not recognize that command. Is there another command? Any help would be greatly appreciated.
*Terry W. Dotson
Message 2 of 7 (3,192 Views)
Re: convert spline to polyline
01-06-2008 10:26 AM in reply to: jbcanam
Grab SPL2PL.VLX from the Free Stuff section of the site below.
Terry
Never start any job without the right tools!
AutoCAD Add-on Tools at http://www.dotsoft.com
*Expert Elite*
JDMather
Message 3 of 7 (3,192 Views)
01-06-2008 02:16 PM in reply to: jbcanam
You have to have the Express Tools installed. Express Tools were included for free with r2007.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
*R.K. McSwain
Message 4 of 7 (3,192 Views)
01-06-2008 07:19 PM in reply to: jbcanam
4 options listed here:
http://rkmcswain.blogspot.com/2007/06/spline-to-polyline.html
R.K. McSwain
*Adesu
Message 5 of 7 (3,192 Views)
01-06-2008 08:02 PM in reply to: jbcanam
Hi jbcanam,
test this my code
[code]
; cstp is stand for Convert Spline To Pline
; Design by : Adesu
; Email : mteybid@yuasabattery.co.id
; Homepage : http://www.yuasa-battery.co.id
; Website : http://cadesu.multiply.com
; Create : 27 August 2007
; Program no.: 0646/08/2007
; Edit by :
(defun massoc (key alist / x nlist) ; Jaysen Long
(foreach x alist
(if
(eq key (car x))
(setq nlist (cons (cdr x) nlist))
(reverse nlist)
(defun c:cstp (/ cmt len sp ss sse)
(if
(setq ss (car (entsel "\nSelect an object spline")))
(progn
(setq sse (entget ss))
(setq sp (massoc 10 sse))
(setq len (length sp))
(setq cmt 0)
(repeat
len
(command "_pline" (nth cmt sp)(nth (1+ cmt) sp) "")
(setq cmt (1+ cmt))
) ; repeat
(command "_erase" ss "")
) ; progn
(alert "\nInvalid selected object,try again")
) ; if
(princ)
[/code]
wrote in message news:5813437@discussion.autodesk.com...
*Gehenna
Message 6 of 7 (3,192 Views)
01-06-2008 09:01 PM in reply to: jbcanam
Adesu wrote:
> Hi jbcanam,
> test this my code
> [code]
> ; Design by : Adesu
> ; Edit by :
> (foreach x alist
> (if
> (eq key (car x))
> (reverse nlist)
> (if
> (progn
> (setq cmt 0)
> (repeat
> len
> (setq cmt (1+ cmt))
> ) ; repeat
> ) ; progn
> ) ; if
> (princ)
> [/code]
Using your lsp code, I get the following error message:
; error: no function definition: KEY
*Adesu
Message 7 of 7 (3,192 Views)
01-06-2008 09:48 PM in reply to: jbcanam
Hi Gehenna,
it's ok no problem, maybe you loss one string, or not completed your copy.
"Gehenna" wrote in message
news:5813592@discussion.autodesk.com...
Adesu wrote:
> Hi jbcanam,
> test this my code
> [code]
> ; Design by : Adesu
> ; Edit by :
> (foreach x alist
> (if
> (eq key (car x))
> (reverse nlist)
> (if
> (progn
> (setq cmt 0)
> (repeat
> len
> (setq cmt (1+ cmt))
> ) ; repeat
> ) ; progn
> ) ; if
> (princ)
> [/code]
> Any
You are not logged in.
Announcements
    Come hangout with Autodesk Support Specialist and AutoCAD guru Volker Cocco, to learn about Precision Drafting: Object Snaps and Object Tracking on July 31 @ 11:00 AM PST.
    Click here for registration information!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
