AutoCAD 2007/2008/2009
russwood
Message 1 of 4 (1,657 Views)
can't copy multiple objects
1657 Views, 3 Replies
01-19-2012 01:00 PM
This is probably a stupid question.  For some reason the copy command suddenly started only allowing to select one object.  If I click copy and select a line, then select a second line, it selects the second line and de-selects the first line.  It does allow me to copy multiple objects using a crossing window.  But I cannot individually click multiple objects as it will deselect the previous object with each new click.  I'm sure this must be a simple setting that got unchecked somewhere.
thanks
Johneng
Message 2 of 4 (1,655 Views)
Re: can't copy multiple objects
01-19-2012 01:06 PM in reply to: russwood
Is your PICKADD system variable set to 1?
russwood
Message 3 of 4 (1,651 Views)
01-19-2012 01:11 PM in reply to: Johneng
thanks I knew it was simple :smileywink:
New Member
jhernandez-barrow
Message 4 of 4 (1,275 Views)
01-09-2013 02:47 PM in reply to: russwood
Had the same problem with Civel 3D 2011 and this is how I fixed it:
* Type in OPTIONS in cammand line, to get Options Dialog Box.
* Click SELECTION tab.
* Under Selection Modes, UNCHECK the "Use shift to add to selection" box.
Good Luck - JHB
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
