While I am drawing, I try to save about ever 5 min or so. But sometimes I can save and it fine, other times I do a save and it tells me that its read-only. I have to do a "save as" and rename the file. Why? How do I fix it?
I have another problem, the model/layout tabs on the bottom left of the drawing area disappear. I looked in page set-up and the show model/layout tab box is checked. I tried the right click on the quick view layout, to show tabs. But that doesn't work either. Any help will be greatly appreciated.
Thanks for any help,
sblue0429
Welcome to the Autodesk Forums!
1. How do you open your files to begin with and where are they kept? Hardrive? Flash Drive? Network?
2. Is this something new? Did you change monitors or screen resolution?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Obviously changing to Read-Only is a problem if it is happening at random. You did not answer if you are saving to a Harddrive or some other media.
What is your OS? Win XP or Win 7?
Any third party programs running with CAD? Unless you can find a trigger for these happenings there will only be random guesses as to a cure.
