i want to re-install my autocad 2008 but the activation code is missing. i don't now were it is. the serial number of the product is xxx-xxxxxxxxx
can you please let me now the activation code so that i can use my autocad cause i really need it for my studies. thanks in advance..
Edited by
Discussion_Admin
Solved by jessica.t. Go to Solution.
You shouldn't post any of the product numbers here, people will steal it.
You run Autocad and activate it online.
I have new download AUtoCAD 2008... i don't have serial number 😞
serial number : 000-00000000
request code : PAF7 9F1L A1G5 ZQ53 S7ZK NLU6
could you tell me the serial number for me ?
send e-mail = ms201193@gmail.com
please ...
@Anonymous wrote:I have new download AUtoCAD 2008...
Where did you download this "new download AUtoCAD 2008... "?
Sounds like a pirated software.Your reseller should provide your serial number.
Students can get AutoCAD 2012 for free from http://www.autodesk.com/edcommunity
hi...i have a Autocad 2008 ,,,,
the serial is 000-00000000
the Request Code is N0AG 9ADN PK1P YY53 XLK5 NUJX
Could u please send me the serail Number At Email address : klaudio.el@gmail.com
i dont remmember well....here in autodesk i got the autocad 2012...it works OK..but i dont like it and i wanted the 2008 version....
If you requested a DVD back then, they gave you 30 days to play with it.
Did you decide to pay for it ? a few thousands dollars ?
Autodesk wouldn't make a dime selling old stuff, so your best bet is to use 2012
Hey i am an engineering student and i need Autocad 2008 version only as it is used in my college i got this software from a senior with serial no. 000-00000000 and request code- RVNSV2D6NVG9NV LYP3 QFXV ZTL1 please send the activation code for this on mitalrajat1993@gmail.com asap
thanks 🙂
a) 000-00000000 is not a valid serial number
b) you won't get a code with no lincense-information (company, name, adress, ...)
c) you won't get a code from anyone in this forum as this is not the place for getting activation codes
So you have to go the same name all others do: during activation (where you saw the request-code) you see methods of how to activate (direct through internet, by mail, by fax).
- alfred -
You can get AutoCAD 2011, 12 or 13 for free from http://www.autodesk.com/edcommunity
and set it to look and save like 2008.
Install and follow the on-screen instructions to activate your license.
I just download AutoCAD 2008 but i donot have my activision code. my request code is Y44Y SE21 6XUR GA53 JGHL HV4H. please send me the activison code via email.
If you have downloaded AutoCAD 2008 today I would guess it was not from an official Autodesk-site.
Additionally here (in the forum) is no place for auth-code-requests, you have either to contact your dealer or Autodesk through the subscription-center. You can also read >>>this info<<< about activation-codes.
BTW: don't think that Autodesk will send activation-codes without knowing who you are and what serial-number you have. 😉
- alfred -
@Anonymous wrote:I just download AutoCAD 2008 ...
What is the url of the download site where you got the software?
Hi hatem.nour2000,
Can you please send me your serial number and request code via private message (click on my screenanme camilo.lemos and then on Send Private Message).
Thank you,
Hi, I have a regular license for AUTOCAD LT 2008 and I have been using it until few days ago.
Now I am no longer able to access the tool because I get an " error 11 " too many reactivations. I have installed this software only on my work PC and never tried to install it anywhere else.
I have contacted the help desk and they provided a new activation code, but it was only a temporary code, after some days I have the same problem and can't work.
Can you please let me know how to reset this activation status and have my software working properly ?
Thank you
