Hi, I have ACAD 2008 on windows XP Pro. I have one file that crashes CAD when I try to print. It was working fine the other day but has just started crashing. Have tried other files and they print OK. I have copied and pasted into a new drawing but still no good. I have attached a JPG of the error message. I have also tried only pasting a small part of the original drawing into a new drawing but still no good.
Hope you can help.
Solved by pendean. Go to Solution.
open the drawing with command _REVOVER (or if it contains XRef's then with command _RECOVERALL), so if there are errors in the drawing database they get cleaned.
Next option is to run command _WBLOCK from this defect drawing and create a new drawing then, after that open the new drawing and try plot again.
And if all that fails try to plot the drawing using another plotstyle and another plotdriver (e.g. "DWF6 ePlot.pc3") just to make sure it's not depending on one of those settings.
- alfred -
