AutoCAD 2007/2008/2009
Valued Contributor
kevinsir
Message 1 of 11 (447 Views)
Accepted Solution
about Block reference?
447 Views, 10 Replies
01-29-2013 01:35 AM
I have two the same the dwg file A and B. I create a new a single layer in A and move all entities to this single layer, then delete all layers in A reserved for the layer and 0 layer . Then open the B, insert the block A to B. Now, everthing is Ok except the color. In my mind , the color of block A in B will have the same color because I set all the entities color bylayer,but it is not. Why is that and How can I set the color of these entities to the color of the singe layer? the follow Attachments first is A, second is B
*Expert Elite*
3wood
Message 2 of 11 (438 Views)
Re: about Block reference?
01-29-2013 02:35 AM in reply to: kevinsir
The reason is because in both drawing A and drawing B there are blocks with same names. Hence when Drawing A is inserted into B, the block definition in drawing B take priority.
So the solution is, instead of INSERT, please use XREF.
Valued Contributor
kevinsir
Message 3 of 11 (429 Views)
01-29-2013 02:56 AM in reply to: 3wood
Thanks for your reply,I will try
Valued Contributor
kevinsir
Message 4 of 11 (387 Views)
01-29-2013 06:51 PM in reply to: kevinsir
Maybe XREF it does not meet my requirements。When i delete the A file out, The block A in B is also been deleted. Have any other Ideas?
*Expert Elite*
3wood
Message 5 of 11 (385 Views)
01-29-2013 07:00 PM in reply to: kevinsir
Bind the xref with Bind type of 'Bind' (not 'Insert") will do.
Valued Contributor
kevinsir
Message 6 of 11 (378 Views)
01-29-2013 07:44 PM in reply to: 3wood
I am sorry that I am new. when I  Bind the xref with Bind type of 'Bind' The A block is invisible. but the layer of A is exist,maybe having something that i do not take notice
*Expert Elite*
3wood
Message 7 of 11 (374 Views)
01-29-2013 08:28 PM in reply to: kevinsir
There are errors in both of your files. You need AUDIT to fix them before XREF A to B.
I attached the successful result below.
Always ensure the files are from trusted sources.
Valued Contributor
kevinsir
Message 8 of 11 (371 Views)
01-29-2013 09:05 PM in reply to: 3wood
Thanks . I will try!
Valued Contributor
kevinsir
Message 9 of 11 (359 Views)
01-29-2013 11:23 PM in reply to: 3wood
Thanks very much for your help. I think you have solved my problem。 Howerver do you have any time to solve my other problem follows。
A1 and B1
 In both drawing A1 and drawing B1 there are blocks with same names
But color of A1 is not changed with B1 when insert A1 into B1
Can you help me to find the reason!
*Expert Elite*
3wood
Message 10 of 11 (355 Views)
01-30-2013 12:07 AM in reply to: kevinsir
In your previous drawing A, in the block which color follows drawing B when inserted, there are some entities which layer is 'xxxx'. But in drawing B, the block with the same name has entities which layer is 'yyyy'. So when drawing A is inserted in B, such block definition in drawing A is ignored and the color will be the same as Layer yyyy.
In your drawing B1, entities in blocks are put in Layer 0 and color are set to ByLayer hence its color is not determined by Layer 0 but the block layer instead. When drawing A1 is inserted into drawing B1, the block definition is replaced with the one defined in drawing B, so the block color is same as its layer color. The blocks in B1 are in Layer 'ssss' which is green but the same blocks in A1 are in Layer 'tttt' which is white.
In a summary, check the block definition in drawing B1. If the sub-entities are set on Layer 0 and Color Bylayer, the same blocks in inserted drawing will keep its own layer color.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
