AutoCAD 2007/2008/2009
Distinguished Contributor
jcole
Message 1 of 7 (9,714 Views)
Text frame around mtext
9714 Views, 6 Replies
10-14-2010 01:02 PM
Am I missing it? Why can you make a text frame (that will follow the boundaries of the mtext box when edited) so easily around multileader text but the same option is not available for mtext?? I don't want TCIRCLE - that will not change with the text changing... ?
TherealJD
Message 2 of 7 (9,628 Views)
Re: Text frame around mtext
10-18-2010 07:12 AM in reply to: jcole
not available with reg mtext.. weird eh?
I've been wanting that feature for mtext and attributes..
*Pro
Modman_4
Message 3 of 7 (9,606 Views)
10-19-2010 06:00 AM in reply to: TherealJD
There was some leader text object I picked up somewhere sometime, that had the rectangular frame around the text that would resize when the text changed. I was able to use it in a similar dashion by making the leader so short it couldn't be seen on the plot. sometimes it would act screwy but most times it did what you are looking for, so perhaps if you tried looking for leaders of a similar type?...
I hope my info was useful, but if by some odd chance it actually solved your issue, feel free to mark your post as "Accept as Solution". Thanks! :smileyhappy:
Active Contributor
Melnyk
Message 4 of 7 (9,599 Views)
10-19-2010 08:20 AM in reply to: jcole
I achieve this by placing a table which is 1 cell only with a border.
However, it will resize the height automatically as you place text, but not the width.
Not sure I've ever seen anything else.
Mike
AlistairBean1906
Message 5 of 7 (9,584 Views)
10-20-2010 03:15 AM in reply to: Melnyk
As th OP pointed out the MLeader command handles this very well.
So just creat one then remove the actual leader part of the object.
jcole
Message 6 of 7 (9,581 Views)
10-20-2010 04:57 AM in reply to: AlistairBean1906
Since I first posted, I did find that you can use multileader and delete the leaders, but I have one more question: is there any way to adjust the line surrounding the mtext so that it is not so close to the text?
Employee
Bob.Felton
Message 7 of 7 (9,406 Views)
12-07-2010 09:39 AM in reply to: jcole
If you use a qleader and select the option in Settings to Frame text, then you can adjust the Text Offset in properties like this:
 2378i9046FF03B2AAF6C9
Bob Felton
Autodesk Product Support
Autodesk, Inc.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
