AutoCAD Forum
Spline text Help please
2 REPLIES 2
hudsonrver
662 Views, 2 Replies
I have text made of splines and any part of the letters that should show as white is filled in black. I see that the shapes are there when I run my cursor over the letters, how do I make them punch out of the text (appear as they should)?
I used the Hatch command on the letter outlines, sent the larger text hatch to the Back, sent the "holes" in the lettering to the front in the hatch command and also with right clicking them and going to Draw Order.
I attached a copy of the text so you can see what i mean.
Thank you so much for any help.
2 REPLIES 2
Patchy
in reply to: hudsonrver
You want to cut a hole inside the text?
Click on the inside hatches, right click mouse button, Generate Boundary then use the new boundaries to trim the hatch.
hudsonrver
in reply to: Patchy
Thank you so much Patchy, that does the trick! Much appreciated. 🙂
”Boost
