AutoCAD 2007/2008/2009
Distinguished Contributor
dmmeehan
Message 1 of 5 (264 Views)
Slow zoom in paperspace viewport
264 Views, 4 Replies
04-10-2007 06:14 AM
I added another layout tab (copy of 1st tab) and when I try and change the scale by zooming in the viewport it takes about 1-2 minutes to regen the dwg. I have purged/recovered the xref as well as the dwg. It fixes many acdbsortent errors and says it is fixed. I had thought it was related to caching layout tabs so I switched to regen when switching. This is the 3rd time it has happened using this particular xref. (A fairly large civil background) I have xcliped to try and improve the speed to no avail. Please help.
dmmeehan
Message 2 of 5 (264 Views)
Re: Slow zoom in paperspace viewport
04-10-2007 06:18 AM in reply to: dmmeehan
some more info. If I open task manager while waiting for the regen Autocad shows not respoonding. It doesn't crash though and eventually finishes the regen.
steve216586
Message 3 of 5 (264 Views)
04-10-2007 07:15 AM in reply to: dmmeehan
You admittingly say this is a fairly large reference file but yet expect immediate results for regen? This is the nature of the program. The more complex or large a file is, the more code the program must read.
I work with large civil files daily and a 1-2 minute regen at plot is not uncommon. I do admit that I have learned a few tricks to work around this though. e.g. All hide situations wait till the end.
dmmeehan
Message 4 of 5 (264 Views)
04-10-2007 07:39 AM in reply to: dmmeehan
I am not plotting. I am adjusting the zoom or panning. I need to rotate the ucs in some viewports. After rotating the view autozooms to extents and I must zoom back to my dwg area before setting the scale. The dwg worked fine with one layout and another dwg worked fine until I hit 16 layouts. Also I thought xclip was supposed to speed this up as well as overly instead of attach. This appears to be a bug with the zoom/pan. If i set the scale through the layout toolbar the regen is instant. I have worked with much larger models and not had this happen in (2005/2006)
Valued Mentor
hardin
Message 5 of 5 (264 Views)
10-25-2007 02:45 PM in reply to: dmmeehan
We are experiencing long viewport zooms when changing annotation scale of the viewport. 15 minutes or more. I think they occur when the xref has annotative objects in it. If we unload the xref before the annotative scale change, then it's almost instant.
Lyle.
You are not logged in.
Announcements
    Come hangout with Autodesk Support Specialist and AutoCAD guru Volker Cocco, to learn about Precision Drafting: Object Snaps and Object Tracking on July 31 @ 11:00 AM PST.
    Click here for registration information!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
