AutoCAD 2007/2008/2009
Active Contributor
radinplaid
Message 1 of 4 (386 Views)
Settings migration from non-operational install of AutoCAD 2008
386 Views, 3 Replies
03-30-2012 12:49 PM
I recently had a run-in with a less-than-competant IT consultant. He was trying to install some drivers for a different program, but it created the unintended side effect of making it so that AutoCAD would no longer launch. Each time I have tried to launch it (by itself or by opening a file) I am met with the following error: "The application was unable to start correctly (0xc01500002). Click OK to close the application."
When I informed him of this, his answer to the situation was to get me a new computer. I'm not complaining since my computer was probably 4+ years old & running Vista Business, but now I am in the undesirable situation of having lost any semblance of what I had done to make my install of AutoCAD personalized. I understand that there is a way to export settings, but if I'm not mistaken that is based on the assumption that you can load AutoCAD. I still have access to the hard drive (it is plugged into my new box for now) and all my data, I just don't know if there is a way to transfer my settings and whatnot to the new installation of AutoCAD on the new drive. Any help would be VERY much appreciated.
Thanks!
*Expert Elite*
Message 2 of 4 (325 Views)
Re: Settings migration from non-operational install of AutoCAD 2008
04-01-2012 03:28 PM in reply to: radinplaid
Are you aware that ACAD 2008 is not officially supported on Win 7. There are a few workarounds, you just have to do a search on the group.
I believe the migration utility just reads the setting files and does not actually require the original program to be in a running condition. Hopefully somone who has had more experience with migration will be able to confirm that.
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
Active Contributor
radinplaid
Message 3 of 4 (313 Views)
04-02-2012 06:03 AM in reply to: Icemanau
Thanks for the reply, Brad. I was not aware that ACAD 2008 wasn't officially supported in Win 7, but I also have not yet experienced any problems. I will have to look into that.
It was my understanding that the export/migration command needed to be run within ACAD, I guess I was thinking of something else. However, now that I know what to look for, I tried to run the AdMigrator.exe but it has crashed every time. The same .exe located in the new install folder will run, but I'm thinking that would just try to export my settings from the new installation, which wouldn't really help. If I knew which files to look for, could I simply copy/paste them from my old install folder to the new one? If so, which files should I be looking for?
*Expert Elite*
Message 4 of 4 (303 Views)
04-02-2012 03:32 PM in reply to: radinplaid
I've never used the migration utility so I wouldn't know how it works.
Have you tried looking in the Help and doing a search for migration...
Regards Brad
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
