AutoCAD 2007/2008/2009
Active Contributor
trvlnmny
Message 1 of 8 (259 Views)
Segmenting Long Pieces?
259 Views, 7 Replies
09-01-2012 02:51 PM
I am using AC LT 2008.
I am not a professional and on the steep learning curve.
I am doing a drawing that has a very long piece 48" x 1/2".
I do notwant to take up all the space the 48" piece will take.
I have seen drawings where long pieces were shown as segments but when dimensioned the full dimension is shown.
Can I accomplish this?
If so How?
Thanks for any and all help.
*Expert Elite*
Patchy
Message 2 of 8 (251 Views)
Re: Segmenting Long Pieces?
09-01-2012 07:10 PM in reply to: trvlnmny
Easily done with DIMENSION SCALE FACTOR (DIMLFAC)
*Expert Elite*
scot-65
Message 3 of 8 (228 Views)
09-04-2012 04:02 PM in reply to: trvlnmny
Another method is to apply a text override.
Open your PROPERTIES floating window.
Highlight the dimension.
In the text section add your desired length.
I would suggest changing color of the dimension object
to a color of the same lineweight so you will not be confused
that the dimension is overwritten to a fixed value.
Note: Using "<>" keeps the dimension associative and still be
able to add a text prefix or suffix: "<> NOT TO SCALE".
Scot-65
Dyslexia is a permanent physical disability that cannot be seen.
Active Contributor
trvlnmny
Message 4 of 8 (216 Views)
09-05-2012 02:59 PM in reply to: trvlnmny
Patchy & Scot-65,
Thank you both for your help.
The piece that I still do not know how to do is to
show a break in the pieces using a jagged line to indicate the break.
While wandering thru Help I entered jog. From the menu returned I selected
Dimension Jog (Procedure). This showed Object(s that had a break in it with the
jogged lines.
It also included a short  video but that was only how to put a jog in the dimension leaders.
I want to know how to get the jog into the object.
Thanks again.
*Expert Elite*
scot-65
Message 5 of 8 (214 Views)
09-05-2012 03:14 PM in reply to: trvlnmny
If you have Express loaded, the break symbol should be in there (I don't use it).
I insert break symbols manually, copy over a little, then trim in between.
Scot-65
Active Contributor
trvlnmny
Message 6 of 8 (209 Views)
09-05-2012 04:45 PM in reply to: scot-65
Scot-65,
When I go to Help I do not find anything on Express so I guess I do ot have it.
I am curious what it is. Can you tell me.
It will be easy enough for me to draw the zig zag indicating a break.
I just assumed that something like trha which is somewhat common woould be included.
Thanks for your help.
*Expert Elite*
Patchy
Message 7 of 8 (206 Views)
09-05-2012 06:00 PM in reply to: trvlnmny
Lt doesn't have Express.
*Expert Elite*
scot-65
Message 8 of 8 (190 Views)
09-06-2012 03:21 PM in reply to: Patchy
Thanks Patchy.
OP:
Basic AutoCAD does not supply one with a symbol or block library.
There simply are too many disciplines that use this software.
There are third-party libraries that can be downloaded (for a price)
for your discipline, however it would be best to create your library
as you go forward. Our server now has over 7,150 files occupying
1.36 GB of hard drive space.
Scot-65
You are not logged in.
Announcements
    Come hangout with Autodesk Support Specialist and AutoCAD guru Volker Cocco, to learn about Precision Drafting: Object Snaps and Object Tracking on July 31 @ 11:00 AM PST.
    Click here for registration information!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
