AutoCAD 2007/2008/2009
KenJG
Message 1 of 5 (236 Views)
Scanning Drawing While Saving/Printing
236 Views, 4 Replies
12-12-2012 09:47 AM
Hello All,
I have an issue with a drawing created in AutoCad 2002.  Whenever I open it to edit it and then either Print or Save it shows Scanning Drawing and takes considerable amount of time for this process.  I have done a purge so far but that did not help.  Any suggestions?
Best Regards
KenJG
Thank You
KenJG
*Expert Elite*
pendean
Message 2 of 5 (230 Views)
Re: Scanning Drawing While Saving/Printing
12-12-2012 12:56 PM in reply to: KenJG
scanning drawing? So the problem is this one file? Is the location of it unique? Is the file unique compared to others you use?
PURGE doesn't fix anything, try AUDIT or RECOVER and see if that helps.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
*Expert Elite*
Alfred.NESWADBA
Message 3 of 5 (226 Views)
12-12-2012 01:54 PM in reply to: pendean
or run WBLOCK to create a new (cleaned) drawing from your current DWG.
>> scanning drawing?
Yes, I saw that message (long, long ago) in the lower left part of the status bar (where you also see the load-time progress-bar while a file is loading). But at the moment my brain does not get the solution to the awareness.  animierte smilies traurig trauern weinen
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
KenJG
Message 4 of 5 (221 Views)
12-13-2012 09:15 AM in reply to: KenJG
Hello All,
Thanks for the help/replies.  It looks as if the procedure WBLOCK seemed to have solved the problem.  I'm curious on why this fixed the problem, what does WBLOCK actually do?
Best Regards
KenJG
Thank You
KenJG
*Expert Elite*
scot-65
Message 5 of 5 (214 Views)
12-13-2012 03:40 PM in reply to: KenJG
Writes a new header section of the DWG file in current format and inserts the existing objects inside.
Once inside, these objects are also updated to the current format/structure.
Educate yourself by DXFOUT the file and open this newly created file using a ASCII text editor (notepad).
Scot-65
Dyslexia is a permanent physical disability that cannot be seen.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
