AutoCAD 2007/2008/2009
New Member
Message 1 of 4 (499 Views)
ScaleListEdit Macro
499 Views, 3 Replies
11-14-2012 01:10 PM
I am working in AutoCAD 2008, and find that it runs slowly due to annotative scales embedded in the drawing.  I frequently use the "Scalelistedit" command to reset the scales embedded in the drawing.  I would like to write a macro, or lisp routine, that runs the "Scalelistedit" command as part of the "Qsave" command.  I have written the macro, but would like to assign it to my alias "Q" for "qsave" so it runs automatically upon saving.  The macro string that I was trying to use is: "_scalelistedit;r;y;e;qsave", however it does not seem to function correctly.  I cannot find anything on the web about how to assign this macro to the alias "Q".  Any suggestions?
Kurt
Alfred.NESWADBA
Message 2 of 4 (491 Views)
Re: ScaleListEdit Macro
11-14-2012 01:56 PM in reply to: vomfell
Means what? Crash? Error message? ....?
BTW: I would start the command SCALELISTEDIT with a dash ( _-SCALELISTEDIT ), otherwise you would get the dialog opened.
- alfred -
Alfred NESWADBA
New Member
Message 3 of 4 (490 Views)
11-14-2012 02:08 PM in reply to: Alfred.NESWADBA
Thanks Alfred,
Ok, I fixed the underscore to a dash, but I still cant figure out how to run the macro, ie. assign a button or alias.
Alfred.NESWADBA
Message 4 of 4 (487 Views)
11-14-2012 02:13 PM in reply to: vomfell
To create a button in your menu you have to use command _CUI and use the syntax above.
If you need that as lisp then you can use the simple (command "...") type like:
(defun C:QS() (command "_-SCALELISTEDIT" "_R" "_Y" "_E")(command "_QSAVE"))
That lisp loaded brings you the new command called QS that should do what you are looking for (at least I hope so :smileywink: )
- alfred -
Alfred NESWADBA
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
