Hello
When i render something it has a black background. AutoCAD2009.
Am i missing something real simple or is there a trick?
Jeff
Solved by Alfred.NESWADBA. Go to Solution.
SCNR: my first repsonse would have been: what do you have in your background? ... if it's "nothing" then: "nothing" can't have a color 😉
Well, there are options to make something not realistic ... like the background-color: start command _VIEW (when you have set the view to how it should be rendered) ==> NEW and within that dialog you can scroll down to define how the background should be represented. Please don't forget to "activate" this new view after creating it.
HTH, - alfred -
