AutoCAD 2007/2008/2009
vthubbard
Message 1 of 7 (856 Views)
Pointer Sticks to Crosshairs
856 Views, 6 Replies
04-07-2011 11:44 AM
I cannot seem to get the mouse pointer/cursor to go away in the ACAD workspace. The last pointer function (hourglass, pointer, pan, etc) is stuck to the crosshairs/pick box. I've combed the discussions and found other people with a similar problem, but not a working solution yet. Any ideas?
Running Civil 3d 2009 in XP mode on a windows 7/64bit machine....niiiiiice.
Actually this must be a Windows XP mode function as a print screen capture i did  to show you what i was talking about only shows the cross hairs...wierd.
thanks in advance!
-adam
vthubbard
Message 3 of 7 (835 Views)
Re: Pointer Sticks to Crosshairs
04-08-2011 07:00 AM in reply to: nestly
Indeed it is an XP issue. One of the above links outlines a method for disabling integration so one can adjust hardware integration in the display->properties->settings->advanced->troubleshooting tab, which solves the problem of the pointer/cursor stuck to crosshairs, but then disconnects me from the network so i can't access the .dwg files.
With a detour to figure out how to reset passwords and login settings in safe mode of virtual xp, i've found this morning to be a rewarding exercise in futility. Still, i'm hopeful there's a solution out there.
*Pro
nestly
Message 4 of 7 (832 Views)
04-08-2011 07:42 AM in reply to: vthubbard
Did you try just turning off hardware acceleration in AutoCAD?
vthubbard
Message 5 of 7 (829 Views)
04-08-2011 08:15 AM in reply to: nestly
That sounds like a good idea. How does one do that?
Thanks for your response!
vthubbard
Message 6 of 7 (823 Views)
04-08-2011 08:41 AM in reply to: vthubbard
I tried the 3dconfig->manual tune->enable hardware acceleration, but the option is greyed out/unselectable.
Time to live with a funky cursor in my cross hairs....i guess
*Pro
nestly
Message 7 of 7 (820 Views)
04-08-2011 08:50 AM in reply to: vthubbard
Bottom right corner, 3rd icon from the edge or 3DCONFIG at the command line.  Normally you'll want hardware acceleration to take advantage of your graphics hardware, but my experience is that it really only makes a difference with the display quality in 3D visual styles, not in the overall speed and virtually nothing in 2D.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
