AutoCAD 2007/2008/2009
*Dilip Damle
Message 1 of 22 (349 Views)
Not Trusted dwg warning even after saving
349 Views, 21 Replies
08-24-2007 10:07 PM
Hello everyone,
When you open a drawing savad by some other application
you get the warning "This drawing was saved by an application
not developed or licensed by Autodesk................."
But after I save/saveas and close the Drawing from A2k8
This message should not be shown the next time.
But I can not get rid of this message. Is it normal?
rgds
Dilip Damle
Life will be much easier if we just have a printout of
all the commands that exist in Autocad kept handy.
*Matt Kolberg
Message 2 of 22 (349 Views)
Re: Not Trusted dwg warning even after saving
08-25-2007 11:13 AM in reply to: *Dilip Damle
Look at tthe DWGCHECK variable to modify the warnings you get.
Check out this link:
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=9078652
Matt
*Tony Tanzillo
Message 3 of 22 (349 Views)
08-25-2007 02:05 PM in reply to: *Dilip Damle
Can you post a copy of the file that causes
AutoCAD to continue to display the FUD
message, even after saving it in 2008?
While I can't confirm it, I suppose it's
possible that Autodesk did something like
the educational 'virus', with files that were
at some point in their life, written by non-
Autodesk products.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
"Dilip Damle" wrote in message news:5700772@discussion.autodesk.com...
Hello everyone,
rgds
Dilip Damle
Active Member
Message 4 of 22 (349 Views)
08-26-2007 07:04 AM in reply to: *Dilip Damle
Here is the file
Distinguished Contributor
Message 5 of 22 (349 Views)
08-26-2007 02:15 PM in reply to: *Dilip Damle
Try running a recovery on the file.
*Tony Tanzillo
Message 6 of 22 (349 Views)
08-26-2007 04:14 PM in reply to: *Dilip Damle
Did you try that, per chance?
*Doug Broad
Message 7 of 22 (349 Views)
08-26-2007 05:32 PM in reply to: *Dilip Damle
That is strange. Auditing and recovering do not discover any errors. Purging and saving
does nothing.
The following choices will make the drawing appear safe but I am uncertain whether you
will lose anything valuable that is hidden.
1) Dxfout. Start a new drawing and dxfin.
2) Start a new drawing. Insert the problem drawing (exploded).
Strange that the application creating it made all the circles into splines. Nice looking
drawing though.
wrote in message news:5701247@discussion.autodesk.com...
Here is the file
*Gehenna
Message 8 of 22 (349 Views)
08-26-2007 06:27 PM in reply to: *Dilip Damle
Dilip Damle wrote:
> Hello everyone,
I Superpurged the dwg and copied and pasted and now do NOT get the
warning. changed the name slightly. See the attached.
*Tony Tanzillo
Message 9 of 22 (349 Views)
08-27-2007 05:37 AM in reply to: *Dilip Damle
Well, it certainly does seem to be
'virus-like' behavior, because
purging; recovering (which finds no
errors), and saving in AutoCAD
2008, does not change anything, and
as per the screenshot
below,
the ObjectARX API is reporting that
the file was not saved
by
Autodesk software.
[img src="@164698"]
Here is the
file
*Jim
Message 10 of 22 (349 Views)
08-27-2007 06:51 AM in reply to: *Dilip Damle
Autodesk does have a utility to convert files saved by other programs. DWG
TrueConvert 2007. It seems to work - so far - for older drawings that I
have saved using other programs.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
