AutoCAD 2007/2008/2009
Member
Message 1 of 5 (198 Views)
Accepted Solution
Multiple Maps, One Object.
198 Views, 4 Replies
12-04-2012 08:41 AM
Hi all,
I want  the interior of a model to render white and the exterior to render in another color, say red, using a plaster map or a stucco map.  When I used to work with my Pfaces it was pretty easy (one face in the inside, one face for the outside) but with solids seems to be pretty hard to have different colors or different textures on each side of a wall.
Please don't tell me that I have to model the inside apart from the outside In order to have different colors and see the house interiors white when you look at it from the outside through the windows.  I just want to create the spaces subtracting a group of solids from the main volume.
Ch.-
*Expert Elite*
Alfred.NESWADBA
Message 2 of 5 (192 Views)
Re: Multiple Maps, One Object.
12-04-2012 09:51 AM in reply to: changmarin
Ok, so I DON'T TELL YOU that ....
And now look to reality (what you try to emulate with your visualisation), the material of the wall is another material than tiles or wallpapers or the paint color you "mount onto the wall". If you want white walls inside and yellow outside you can't use one material for building the wall anyway.
Realism is not easy at all! :smileyhappy:
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Member
Message 3 of 5 (189 Views)
12-04-2012 10:15 AM in reply to: changmarin
Hi Alfred,
Don't get me wrong, I've read the manual thoroughly and supposed just that.  I understand the different color or tile is another material.  I just hoped that with one "mysterious" command or lisp routine I've never heard of you could assign different textures to the solids faces the same way you can assign different colors to their faces.
Thanks anyway, I appreciate it.
Ch.-
Member
Message 4 of 5 (179 Views)
12-05-2012 07:00 AM in reply to: Alfred.NESWADBA
My dear friend Alfred,
Guess what,  it can be done!  The "mysterious" command is SOLEDIT, then choose option Face and proceed to select the solid's face to be modified and change the map independently from the rest.  You can also select the face directly and after that choose a map from the list in the properties window.
:smileyhappy:
Ch.-
*Expert Elite*
Alfred.NESWADBA
Message 5 of 5 (175 Views)
12-05-2012 07:09 AM in reply to: changmarin
great, so I have to apologize (and start with a new world/dimension of AutoCAD materials).
Thx for the correction!
- alfred -
Alfred NESWADBA
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
