AutoCAD 2007/2008/2009
Active Contributor
Message 1 of 6 (910 Views)
Missing DirectX d3dx9_30.dll after AutoCAD 2008 deployed through Group Policy
910 Views, 5 Replies
02-27-2008 03:37 PM
After deploying AutoCad 2008 through Group Policy, users are receiving this error message when they open AutoCad:
"acad.exe - Unable to Locate Component"
"This application has failed to start because d3dx9_30.dll was not found."
After some research I found that this dll is apart of Microsoft's DirectX 9.
The user's do not have the d3dx9_30.dll in their system32 folder.
After manually installing DirectX on my machine (AutoCad 08 is not installed) I have the d3dx9_30.dll in my system32 folder.
Has anyone had any experiencing with resolving this error message?
Does anyone know if there is an msi available for DirectX 9?
Has anyone been able to successfully deploy AutoCad 2008 through Group Policy without the above mentioned error message?
Thanks in Advance
Member
Message 2 of 6 (910 Views)
Re: Missing DirectX d3dx9_30.dll after AutoCAD 2008 deployed through Group Policy
02-29-2008 06:27 AM in reply to: Chris E
i have also had thiss issue... but have found that the MST file is not doing its job... so there fore the additonal parts are not being installed i.e. MSMXL6.0 and DWF Viewer???...
Member
Message 3 of 6 (910 Views)
03-01-2008 01:56 AM in reply to: Chris E
Chris E,
I have done some work with regards to your message as I had the same issue!... I have created a MSI file using the DirectX setup included with AutoCAD 2008. If you would like a emailed copy of this please add your email address to this forum!
Regards
Stickymicky
Active Contributor
Message 4 of 6 (910 Views)
03-01-2008 07:14 AM in reply to: Chris E
cte@bellsouth.net
Thanks, I really appreciate it!
New Member
Message 5 of 6 (910 Views)
05-07-2008 06:51 AM in reply to: Chris E
I would like a copy.
awjohnsn@wapa.gov
New Member
Message 6 of 6 (347 Views)
10-26-2012 08:57 AM in reply to: Chris E
manohar.patil@hp.com   I am also having same issue on machine. Please assist to resolve this issue.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
