AutoCAD 2007/2008/2009
Member
Message 1 of 4 (421 Views)
Invalid Media Configuration Error
421 Views, 3 Replies
06-25-2012 05:45 AM
Hi, all. Long time reader, first time poster.
Windows 7 Ultimate; AutoCAD2009; Oce TDS320, HP T1120 plotters.
I have a rather common error message, it seems. But there does not seem to be a resolution which fits my particular situation.
Recently we updated two computers in our office. AutoCAD runs well, for the most part, but when Plot Preview icon is clicked (or Preview command it typed) the error message “The selected layout has an invalid media configuration” is displayed. Oddly, in my opinion, if the Plot icon (or command) is employed and Preview button is selected from the plot dialog box, a preview of the plot will be displayed. Coinciding with this issue, and quite a bit more troubling, is the inability to Publish drawings. The error from Publish is similar- “The current device does not support the requested media size”. The plotter and media is set up through Page Setup Manager and does not cause any issues on other workstations running AutoCAD2009 and Win XP and has worked without flaw for the last five years.
In review of several posts on this forum, many others' issues have been solved by simply changing either print settings in CAD or printer settings of plotter. These are fine solutions for times when you only need one or two pages, not 70+ sheets. One post mentioned a similar issue to mine, but the only solution posted was to add a new plot configuration to each drawing or to revise all existing plot configs to have a new plot configuration. I can assure you that no one in an architectural or engineering firm has the time, to revise plot configs in thousands of drawings. So, basically, that's not a realistic option. I have also tried running the CAD in the virtual XP OS to no avail.
While AutoCAD2009 is not technically supported by Win 7, this does seem to be an issue which should have a solution- either user based or from Autodesk. We do have plans to update our office to a newer version of AutoCAD but this issue is making us nervous- what other hidden problems will we discover after updating when our entire document base is saved in 2009 or earlier?
Any help with this is greatly appreciated. If more information about our software or hardware is needed, please ask.
Alfred.NESWADBA
Message 2 of 4 (404 Views)
Re: Invalid Media Configuration Error
06-28-2012 01:37 AM in reply to: jhakobe
did you verify that your plotter-settings are set to the correct media used?
Sometimes when you install a plotter-driver on a new system you don't have the roll as it's default media set, instead it's set to A4 or any small single-page-sized format and not 44"roll (or whatever roll-size you use). If the plotter is set to some small page-size then you will get such messages from your AutoCAD.
- alfred -
Alfred NESWADBA
Member
Message 3 of 4 (395 Views)
07-02-2012 11:29 AM in reply to: Alfred.NESWADBA
Alfred- Thank you for the reply.
Yes, I have reviewed the default settings for the plotter, CAD and the individual page setups. All are set to what has been and continues to be our default- Oce D (24x36).
Knowing that, please post if you have any additional ideas.
Member
Message 4 of 4 (382 Views)
07-11-2012 05:13 AM in reply to: jhakobe
Anyone with any ideas at all, please
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
