Is there a way to import text from the spreadsheet, other than using paste special and bringing the spreadsheet data in as an image. I'm working with AutoCAD 2006.
When I used paste special in 2004 paste as AutoCAD entities. My notes would come in as dText, and the format would be identical to the format I had created in Excel. by format. I mean that the columns would be lined up and justified perfectly.
Now that I use 2006+ either text comes in as an image, or as a jumbled and Mtext mess.
Is there a Lisp routine that would make AutoCAD 2006 Behave the Way 2004 did?
Chris-
Really "MText mess"? When I go the same way in 2006 as in 2004 I get an AutoCAD Table object with all options the table object in AutoCAD had in 2006.
If you again want to have single text objects, not grouped together and including table-gridlines you can start command _EXPLODE after inserting, that creates single text objects and lines.
- alfred -
thanks
I'll give it another try.
just hate to explode and move stuff around. i'm lazy
Chris-
Why do you want to explode it then? Leave it as table and use the table's functionalities/advantages!
- alfred -
thank you.
I have tried note pad as an intermediate step. I have not tried CSV though.
usually the result is the same, that is, columuns are not lined up and or justfied.
Chris-
@cadamson2112 wrote:
thank you.
Chris-
As Alfred suggested, "Leave it as table and use the table's functionalities/advantages!"
Create Table Styles with the desired Formatting and also look into what "Remove Property Overrides" does
which will allow an Excel Table to match the Acad Table Style definition.
Linked Tables can be a bit quirky but once set up, columns can be lined up and justified as well as data linked
to the Excel file.
This way the Excel file changes the UPDATEDATALINK command updates the Table in drawing.
