I am a chinese.
The reason is the .Net 2.0.The AutoCAD 2007 is builds by Net 2.0.But it's build the very older version.New PC has new version,so is not very running-in.
The solution to the problem is autodesk rebuild for new net 2.0 for the related to files.The files is computer the thumbnails.
welcome @forums.autodesk.com!
I would not give that any chance .. that Autodesk will now (for a software 7 years old, 7 releases earlier than current) send an update. 😉
What operating system does your new PC have? WinXP ... or an unsupported OS (unsupported for AutoCAD 2007) ... that might be more reason to your issue.
BTW: what makes you thinking that a Framework version is the reason for a different background, imho it's the background color of the last view you have seen in the DWG-file.
- alfred -
the net 3.5 sp1 verson is 3.5.30729.1
the net 3.5 sp1 rebuild-time is 2009-2-27
the net 2.0 sp2 verson is 2.2.30729
the net 2.0 sp2 rebuild-time is 2008-12-14
