AutoCAD 2007/2008/2009
Active Member
Cantafford
Message 1 of 4 (1,352 Views)
How to delete one(or more) of a rectangle's lines
1352 Views, 3 Replies
12-08-2012 03:04 AM
How can I delete one of the rectangle's lines? When I try selecting only one line I can't do it unless I select the entire rectangle. Help please.
For example in this photo I would like to delete line AB:
[IMG]http://i49.tinypic.com/11a9uzm.jpg[/IMG]
Alfred.NESWADBA
Message 2 of 4 (1,348 Views)
Re: How to delete one(or more) of a rectangle's lines
12-08-2012 03:18 AM in reply to: Cantafford
if your rectangle is of type POLYLINE then it's one object. To separate the polyline into it's segments you may use command _EXPLODE, then each of the segments will a be separate line and may be deleted piece by piece.
(just to make sure: to move that object, when it's exploded, makes it necessary to select each of the pieces :smileywink: then )
- alfred -
Alfred NESWADBA
Active Member
Cantafford
Message 3 of 4 (1,335 Views)
12-08-2012 08:57 AM in reply to: Alfred.NESWADBA
Great thanks man!
Valued Mentor
KLYPHY
Message 4 of 4 (1,317 Views)
12-11-2012 06:50 AM in reply to: Cantafford
Since the Rectangle is a polyline, it is an Object. As an Object, it can trim itself. Here's how.
-Start the Trim command,
-Select the Rectangle,
-Hit "Enter" to end the selecting.
-Now, select any of the Rectangle's lines and they will disappear.
The remaining pieces are still Polylines.
Try it; you'll like it. -KLYPH
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
