¿How can I add back this tab?
(the top left bar with arrows: undo, redo....) (This is in the autocad 2009 version, I suposse that will be equal in later versions.
Solved by nestly2. Go to Solution.
Solved by Alfred.NESWADBA. Go to Solution.
first I would try to reload the workspace.
If that does not work you have to start command _CUI, go to group "Quick Access Toolbars" and reconfigure it.
- alfred -
