AutoCAD 2007/2008/2009
Active Member
Message 1 of 4 (137 Views)
Help with Mtext glitch
137 Views, 3 Replies
06-19-2012 03:27 PM
My office has been running into an interesting glitch with MText.  We have a standard text setup when anyone starts a new drawing using our standard templates.  For some reason, the first time you use Mtext, the result is not our standard.  If you use Mtext again, it then will look like our standard.  The weird part is that the settings are identical when you look at the properties.  The only difference is that the first Mtext under "content" of the properties, look like this:
{\W1; text}
This is not the case when you use Mtext again.  It only shows "text".  It only happens the first time you use Mtext after opening a file.  I've attached a PDF of what it looks like.  A is the non-standard first time Mtext.  B is the standard, second time Mtext.
Any ideas?  Is this something that can be fixed?
pendean
Message 2 of 4 (132 Views)
Re: Help with Mtext glitch
06-19-2012 08:08 PM in reply to: wellsws
That glitch plagued 2008 and 2009: ensure your version is fully patched and updated.
If you can post an actual DWG someone might have more tips.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Member
Message 3 of 4 (121 Views)
06-20-2012 07:50 AM in reply to: wellsws
Here's the dwg file.
Active Member
Message 4 of 4 (120 Views)
06-20-2012 07:51 AM in reply to: wellsws
I forgot to mention, we are up to date on updates.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
