While working as per usual on AutoCAD 2009 I randomly revieved this Error while trying to open another file from 'My Documents" on my computer:
FATAL ERROR: Unhandled e06d7363h Exception at fd899e5dh
The Error came up after the file has opened via a small pop up window and when I press th "OK" button the program completely closes. I cannot open and work on any of my drawings.
Please help!
Solved by kendra.coates. Go to Solution.
Welcome to the Autodesk Forums!
New issue for you?
Have you tried RECOVER on the File that you were trying to open?
AUDIT on the current open file when the error occured?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Yes, It is a new issue.
Unfortunately I am unable to type any commands in the program as the pop up window with the error message prevents such.
Change anything on the Computer today?
New program, Windows update, or Antivirus update?
Close AutoCAD and restart. Choose Recover form Drawing Utilities under the Big A
Will this let you Recover the file?
No nothing was changed.
The only other programs open were Microsoft Office Outlook and Youtube (plaing music).
I had three AutoCAD files open at once, but that is quite usual and I've never had a problem before.
We crossed paths. Go back to my previous post about closing and trying Recover on the file.
KB returned this on your error:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=11322398&linkID=9240617&siteID=123112
And the full search:
Sorry but when you say type "recovery" in; do you mean as a command?
Because I am unable to do so.
I cannot even open a new file without receiving the Error message.
Sorry here.
What version are you on?
Tengo este problema con CAD y no se como resolverlo. ¿Alguien puede ayudarme?
