AutoCAD 2007/2008/2009
New Member
Message 1 of 8 (1,847 Views)
Edit OLE object - how to rotate?
1847 Views, 7 Replies
08-06-2008 08:12 PM
Is there a way that i can rotate an OLE object on the drawing? (paper space or model space). I've tried different ways to rotate an OLE object (OLE object chart from MSExcel but not rotating). I've used the MVsetup command to change the view angle of viewport with an OLE in the model space but the OLE object stay on the same angle but other objects within the same viewport rotated. on the properties tool bar, there is no option for rotation.
Your help will be highly appreciated.
*Dean Saadallah
Message 2 of 8 (1,847 Views)
Re: Edit OLE object - how to rotate?
08-07-2008 05:24 AM in reply to: SHASHIKIBUTA
Not an option.
Rotate outside AutoCAD then re-attach.
Dean Saadallah
http://LTisACAD.blogspot.com
Add-on products for LT
http://www.pendean.com/lt
New Member
Message 3 of 8 (1,847 Views)
08-07-2008 03:02 PM in reply to: SHASHIKIBUTA
Thanks for the reply Dean.
Is there a chance for autodesk to enhance the OLE properties and add this rotating option? anyone from autodesk?
I don't want to screw the data on graph that comes from client and it will take a while to rotate it from the MSexcel since sometimes there are more than two data to rearrange.
*Dean Saadallah
Message 4 of 8 (1,847 Views)
08-08-2008 07:31 AM in reply to: SHASHIKIBUTA
They haven't done it yet through 2009... .
Dean Saadallah
Member
Message 5 of 8 (1,365 Views)
11-14-2012 06:10 AM in reply to: SHASHIKIBUTA
I'm running 2013 and it still cannot be done.  I vote for a service pack fix.
Valued Mentor
TerryDotson
Message 6 of 8 (1,362 Views)
11-14-2012 07:52 AM in reply to: SHASHIKIBUTA
I would use a crayon before I would use OLE.
Member
Message 7 of 8 (1,358 Views)
11-14-2012 08:01 AM in reply to: TerryDotson
Terry, Thanks for the really useful help.  This forum is for helping people, not bashing them.  How do you even know what we're up to?  If you're pushing your add-on maybe you should make a nice sales pitch instead of just making people feel like idiots.
Valued Mentor
TerryDotson
Message 8 of 8 (1,350 Views)
11-14-2012 02:25 PM in reply to: aaron_kaczor
I'm not bashing anybody, unless you are a Microsoft employee in charge of Windows OLE you have no reason to be offended.   Also note my reply was to the original poster (who adequatedly explained what they are up to), not you.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
