AutoCAD 2007/2008/2009
Member
dennis.greenlee
Message 1 of 7 (859 Views)
Drawing file is not valid
859 Views, 6 Replies
06-12-2012 12:06 PM
Having a problem with a .dwg file that I have used in the past, when I try to open, I get the dreaded "Drawing file is not valid".
I have opened in WordPad, and there are many characters, but won't open in ACAD.  Drawing is a ACAD 2009 file, but is slightly too large to post here.
Anybody out there with suggestions?  I can zip the file to about 1.58mB.
Thanks in advance.
*Expert Elite*
Patchy
Message 2 of 7 (856 Views)
Re: Drawing file is not valid
06-12-2012 12:32 PM in reply to: dennis.greenlee
Start an empty drawing, type in RECOVER, find this bad drawing.
or
type in WBLOCK, and find this bad drawing.
Member
dennis.greenlee
Message 3 of 7 (854 Views)
06-12-2012 01:01 PM in reply to: Patchy
Thanks again, but
Recover states "unable to recover drawing file",
Unsure on settings for WBLOCK, do I select block, drawing, objects? Source drop down is grayed out, but I can select destination to that original file.  When I do that, file is overwritten...I made copies for protection
*Expert Elite*
Patchy
Message 4 of 7 (850 Views)
06-12-2012 01:05 PM in reply to: dennis.greenlee
Drag the drawing icon to a minimized drawing area and drop it (It works same as insert)
Do you have .bak of that drawing?
Member
dennis.greenlee
Message 5 of 7 (848 Views)
06-12-2012 01:40 PM in reply to: dennis.greenlee
No bak, when I create a new-block.dwg with Wblock, and drag the old drawing onto the model tab, on command line it states: _-INSERT Enter block name or [?]: "F:\backup9-4-10\DENNIS\DMG\rivercrest deck old\12980RIVERCRESTDeck.dwg" ** File F:\backup 9-4-10\DENNIS\DMG\rivercrest deck old\12980RIVERCRESTDeck.dwg was created by an incompatible version of AutoCAD *Invalid* I have used the drawing previously (2011) but now it seems corrupted. Dennis M. Greenlee, P.E. Senior Project Engineer, Flotation Direct +1 801 871 7444 (voicemail only) * Mobile +1 801 209 1276 * Fax +1 801 871 7444 dennis.greenlee@flsmidth.com _____________________________________________ Minerals Engineering FLSmidth 7158 S FLSmidth Drive * Midvale * UT 84047-5559 * USA Tel +1 801 526 2000 * Fax +1 801 526 2923 www.flsmidth.com_____________________________________________ This communication constitutes an electronic communication within the meaning of the Electronic Communications. Privacy Act, 18 USC 2510, and its disclosure is strictly limited to the recipient intended by the sender of this message. This communication may contain confidential and privileged material for the sole use of the intended recipient and receipt by anyone other than the intended recipient does not constitute a loss of the confidential or privileged nature of the communication. Any review or distribution by others is strictly prohibited. If you are not the intended recipient please contact the sender by return electronic mail and delete all copies of this communication.
Member
dennis.greenlee
Message 6 of 7 (832 Views)
06-13-2012 09:19 AM in reply to: dennis.greenlee
I apologize for the extraneous information on previous reply.
Is there some way to modify the header of the drawing in "word" or similar to correct the reading of the file?
*Expert Elite*
Patchy
Message 7 of 7 (829 Views)
06-13-2012 09:23 AM in reply to: dennis.greenlee
I have not seen any program that can edit .dwg in wordpad to make it alive again.
There was a program that can convert .plt back to .dwg but not many people use .plt anymore (but me)
Backup your PC often still a good practice for any offices.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
