AutoCAD 2007/2008/2009
Member
cgreeniow
Message 1 of 6 (255 Views)
Autocad LT view alignment
255 Views, 5 Replies
08-15-2012 06:11 AM
I have a DXF file in Autocad LT which I need to import into a CAD Reader for a CNC machine. The cad reader can only view a 2D image of the TOP of the part. The problem is that the view I want the cad reader to see is the RIGHT hand side  view in Autocad. Is it possible to reassign the views in Autocad LT 2008 so that the right hand side view become the top view therefore allowing the cad reader to see the correct side.
Any help would be greatly appreciated.
Chris
*Expert Elite*
Patchy
Message 2 of 6 (250 Views)
Re: Autocad LT view alignment
08-15-2012 07:04 AM in reply to: cgreeniow
I tried with full version without any 3d commands and it works, so you can try this:
In your original drawing, view the side you wanted to become plan for the CNC machine, type in UCS, then type in F (for Face) , select the object.
After this use CTRL+C (for copy) and select the object.
Start a new drawing, leave its UCS as Plan, use CTRL+V (for Paste)
Let me know if it works for you.
Member
cgreeniow
Message 3 of 6 (245 Views)
08-15-2012 07:15 AM in reply to: cgreeniow
Thanks for replying. That doesn't work. It says 'No solids detected'. I guess this is because I just have a line drawing and not a solid object?
*Expert Elite*
Patchy
Message 4 of 6 (243 Views)
08-15-2012 07:17 AM in reply to: cgreeniow
Maybe, list it and see what it said.
Attach your drawing here, let see if we can find a way.
Member
cgreeniow
Message 5 of 6 (241 Views)
08-15-2012 07:21 AM in reply to: Patchy
Specify origin of UCS or [Face/NAmed/OBject/Previous/View/World/X/Y/Z/ZAxis]
<World>: f
Select face of solid object:
A 3D solid must be selected.
No solids detected.
I will see if I can attach the file if you think that is the easiest way.
Valued Mentor
steven-g
Message 6 of 6 (171 Views)
08-22-2012 10:52 PM in reply to: cgreeniow
A bit late in the day but if you are still looking. It doesn't show up in the options listed but you can tell the UCS to change to TOP, BOTTOM, FRONT, BACK, LEFT, RIGHT
<World>:right
Then copy and paste as mentioned earlier
Regards Steven Gray
Setting Out (Joinery Manufacturing)
Autocad 2013LT
Windows 7 professional
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
