AutoCAD 2007/2008/2009
Member
shilsis
Message 1 of 8 (1,417 Views)
AutoCad 2007 Hatch Patterns
1417 Views, 7 Replies
05-22-2006 01:04 PM
In the past, if I wanted to add an established hatch pattern that didn't come in the box I added it to the ACAD.PAT file and there it was ready to use. I have tried that in 2007 and the new pattern isn't available. I have even changed the name of the ACAD.PAT file it see if Hatch would work in AutoCad and it does work so I am obviously not adding the Hatch pattern to the correct file. What am I doing wrong?
*Gary Fowler
Message 2 of 8 (1,417 Views)
Re: AutoCad 2007 Hatch Patterns
05-22-2006 01:15 PM in reply to: shilsis
Use toolpalettes or designcenter. And make sure the pattern files are
located in a support path.
This way you can use individual hatch patterns. These are placed on our
network.
Gary
wrote in message news:5182487@discussion.autodesk.com...
*Dean Saadallah
Message 3 of 8 (1,417 Views)
05-22-2006 01:25 PM in reply to: shilsis
Make sure the pattern files are located in your AutoCAD
support paths, they should be accessible in BHATCH command
under the Custom option if you want to do the pop-up thing.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
*Warren Trost
Message 4 of 8 (1,417 Views)
05-22-2006 02:36 PM in reply to: shilsis
(findfile "acad.pat")
Checks which file is being referenced.
*George Drayton
Message 5 of 8 (1,417 Views)
05-22-2006 07:24 PM in reply to: shilsis
If your are working in a metric DWG then te hatches are stored in
acadiso.pat
George Drayton CD-CAD Ltd New Zealand
"Warren Trost" wrote in message
news:5182619@discussion.autodesk.com...
*Ralph Sanchez
Message 6 of 8 (1,417 Views)
05-23-2006 05:31 AM in reply to: shilsis
The ACAD.PAT should be in a hidden folder deep within the Documents and
Settings\yourlogin labyrinth. To find it, first start Windows Explorer and
go to Tools / Folder Options / File Types, and ensure that hidden files are
shown. Then dig down into "c:\documents and settings\yourlogin\application
data"
Your best bet, however, may be to define all of your custom hatch patterns
in their own file(s) so that you don't have to append the autodesk-supplied
acad.pat every time you upgrade.
Ralph Sanchez
http://www.texupport.net
*Gary Fowler
Message 7 of 8 (1,417 Views)
05-23-2006 07:20 AM in reply to: shilsis
Also if you want to do a little coding you can create your own hatch making
utility.
This one uses individual hatch patterns that are placed in the search path.
Others have said, but I never modify AutoCAD files.
Gary
"Gary Fowler" wrote in message
news:5182500@discussion.autodesk.com...
network.
Gary
use. I have tried that in 2007 and the new pattern isn't available. I hav=
e
*Gary Fowler
Message 8 of 8 (1,417 Views)
05-23-2006 07:25 AM in reply to: shilsis
Sorry please remove this post
Gary
news:5183176@discussion.autodesk.com...
utility.
Gary
laced on our
network.
Gary
e
the correct
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
